Help with rear disk conversion - Page 3 - JeepForum.com
post #31 of 35 Old 03-20-2012, 04:42 AM Thread Starter
JeepComanche89
1989 MJ Comanche
I was planning on 32s no bigger then 33s on steel rims. Possibly a spare not sure yet. And yes i will have a custom 8in channel bumper in the rear with a receiver bolted to the frame. So my best bet would probably be to bypass the valve and possibly change the valve under the master? Thanks for helping
JeepComanche89 is offline
post #32 of 35 Old 03-20-2012, 07:20 PM
mp15dc
1989 XJ Cherokee
Yeah, bypass the valve. You should be ok with what you have planned. As for the valve under the master, myself i'am going to change it with one from an GC instead of modifing the original. That way i only have too bleed the brakes once.
mp15dc is offline
post #33 of 35 Old 03-21-2012, 04:25 AM Thread Starter
JeepComanche89
1989 MJ Comanche
Ok thanks for the help. I just did some reading and think i will do the GC valve swap as well. Also i will remove the valve in the rear. Thanks for the help. Does anyone know if I can just run one line back to the rear rather then the two that are there now?
post #34 of 35 Old 03-21-2012, 06:49 PM
mp15dc
1989 XJ Cherokee
Yeah you can run one line to the back as the GC valve only has one fitting to the rear brakes.
mp15dc is offline
post #35 of 35 Old 03-21-2012, 06:56 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Awesome thanks just what i was looking for. Thanks for the info
rear disk brake conversion HACKGT350 XJ Cherokee Technical Forum 3 02-07-2012 02:51 PM
Help with Comanche rear disk conversion JeepComanche89 MJ Comanche Technical Forum 14 01-09-2012 12:10 PM
Another Rear Disk Conversion thread dagr8tim XJ Cherokee Technical Forum 8 10-12-2011 08:57 AM
Rear Disk Conversion anyone?? mpdufour XJ Cherokee Technical Forum 14 03-20-2008 02:44 PM
D35 Rear Disk Conversion Miami_XJ XJ Cherokee Technical Forum 4 10-18-2006 11:31 AM
