Help with rear disk conversion - JeepForum.com
post #1 of 35 Old 02-11-2012, 01:44 PM Thread Starter
JeepComanche89
1989 MJ Comanche
I am attempting to do a rear disk conversion on a 89 MJ with a Dana 44 rear axle. I was told parts from a 95 to 98 grand cherokee would be compatible. I ordered rear caliper mounting brackets with dustshields from a 1995 grand cherokee Orvis edition. However the bolt pattern on the mounting brackets is completly different from that of my dana 44 axle. Did I order the wrong parts?
JeepComanche89 is offline
post #2 of 35 Old 02-11-2012, 07:05 PM
Garvin
1986 MJ Comanche
Orvis edition was a trim package mainly. From what I remember, the 5.2L was standard and the 4.0L was optional. If you got the bracket for the one with the 4.0L then the center hole will be a different bore diameter. You will need to enlarge the hole. When you install it, you will have to add a spacer from the Dana 44 Grand Cherokee's to get the proper bearing preload. The link below is for a Dana 44 on a TJ but it's exactly the same for the MJ's.
http://www.stu-offroad.com/suspension/d44brake/bc-1.htm
Other than the center hole, the four mounting bolts will be the same (I did this same exact swap on a buddies Dana 44 a few months back).
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #3 of 35 Old 02-11-2012, 08:41 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Well for some reason the bolt pattern on my axle flange is completely different. Could it be possible a different version of the dana 44 was used in stu's writeup? The axle im using is from a 89 comanche.
post #4 of 35 Old 02-11-2012, 09:04 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Does anyone know what version of a dana 44 was used in a 89 comanche longbed 4x4? And what versoin is used in the writeup from stu's offroad? I was following that writeup and everything seems good except for that the caliper mount does not bolt up to the axle flange.
post #5 of 35 Old 02-11-2012, 09:30 PM
Garvin
1986 MJ Comanche
Might be a stupid question but...You sure you got the left hand one on the left hand side? I forget if the bolt holes are the same side to side or not. As far as I know, all Dana 44's have the same 4 bolt holes, the same goes for the 35's (I've had quite a few 44's and 35's come past my way and they were all the same, from FSJ/XJ/TJ's on the 44's and XJ/MJ/YJ/TJ's on the 35). Might be another stupid question but gotta ask it, are you sure it's a 44 back there and like a 35, 8.25 or AMC 20? Just trying to get all the info straight so I can help out where I can. Also make sure that the brackets that were ordered for the Orvis are for the 44 or 35. Do you have the part number for the brackets?
...RIP...
Garvin is offline
post #6 of 35 Old 02-12-2012, 07:25 AM Thread Starter
JeepComanche89
1989 MJ Comanche
I am almost 100 percent sure its a 44. I compared it with a rear end chart and thats what it appears to be, a sideways apple with a steel drain plug and 10 bolts. I cannot post pictures yet but I would. As for the Caliper mounts everything appears to be the same thing as stu has. I ordered the retaining plates he mentioned based on the part number he gave and they are a perfect match to the grand cherokee mounts , but not the axle flange.
post #7 of 35 Old 02-12-2012, 07:30 AM Thread Starter
JeepComanche89
1989 MJ Comanche
I do not have axcess to the part number of the caliper mounts from the grand, but here is the part number for the retaning plates which match the mounts perfectly 5083678AA. I orded them from morris 4x4.
post #8 of 35 Old 02-12-2012, 08:50 AM
Garvin
1986 MJ Comanche
Not sure exactly what you tell you at this point. If you could snap some pictures, that'd help tremendously. From everything I've experienced and read, assuming your Dana 44 is the factory one, then the '95-'98 (even '94 apparently) brackets will bolt right up to yours.
...RIP...
Garvin is offline
post #9 of 35 Old 02-12-2012, 09:05 AM Thread Starter
JeepComanche89
1989 MJ Comanche
Thanks for your help so far, like i said im unable to post pictures. Im going to try and see if i had put the wrong mount on the wrong side of the axle now like you had said.
post #10 of 35 Old 02-12-2012, 12:05 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Ok the retaining plates part number 5083678AA do not match up to my axle flange no matter what way they are turned. I took some measurements of the bolt holes on my axle flange and the holes measure 3 1/4 across and 1 7/8 apart. I looked into a thread on NAXJA of a crown vic rear disk conversion and the Crown vic mount looks a whole lot similar to my originals then the ones from the grand. Any ideas?
post #11 of 35 Old 02-12-2012, 03:00 PM
Garvin
1986 MJ Comanche
The Crown Vic has the Ford 8.8 rear. I put a picture below of the axle covers, might help with making sure you have the 44 in back and someone didn't swap in the 8.8.
Were the axles bolted in on the outside or is there a c-clip in the differentials that hold the axles in?
...RIP...
Garvin is offline
post #12 of 35 Old 02-12-2012, 03:42 PM Thread Starter
JeepComanche89
1989 MJ Comanche
I do not believe that there is a c clip. To remove the axle shafts i simply unbolted everthing from each end and pulled. If I were to get grown vic or explorers backing plates and teraflex spacers would I be able to use my grand cherokee calipers? Thanks
post #13 of 35 Old 02-12-2012, 05:05 PM
mp15dc
1989 XJ Cherokee
To use the grand cherokee backing plate, you have to slot or redrill the holes to match. Same with the new retainer plate. Im going to do the same thing to my dana44.
mp15dc is offline
post #14 of 35 Old 02-12-2012, 05:23 PM
mp15dc
1989 XJ Cherokee
The TJ dana 44 has a different bolt pattern then the XJ/MJ dana 44. I have 01 crown vic pads that fit the 96 grand calipers/backing plates. I didnt get crown vic parts as didnt want to change rims yet, heard u need more than 4" backspacing to clear the caliper on some wheels. Hope some of this helps.
mp15dc is offline
post #15 of 35 Old 02-13-2012, 08:18 AM Thread Starter
JeepComanche89
1989 MJ Comanche
Yes that helps thanks. So do u have WJ backing plates that are redrilled? Can i use 95 to 01 explorer backing plates with stock rims or do i still need more backspacing
rear disk brake conversion HACKGT350 XJ Cherokee Technical Forum 3 02-07-2012 02:51 PM
Help with Comanche rear disk conversion JeepComanche89 MJ Comanche Technical Forum 14 01-09-2012 12:10 PM
Another Rear Disk Conversion thread dagr8tim XJ Cherokee Technical Forum 8 10-12-2011 08:57 AM
Rear Disk Conversion anyone?? mpdufour XJ Cherokee Technical Forum 14 03-20-2008 02:44 PM
D35 Rear Disk Conversion Miami_XJ XJ Cherokee Technical Forum 4 10-18-2006 11:31 AM
