HELP np 231 shift linkage - JeepForum.com
post #1 of 3 Old 10-24-2012, 08:41 PM Thread Starter
JeepComanche89
1989 MJ Comanche
I swapped a AX-15 trans with a NP-231 t case in my 88 comanche. The trans came from a 95 cherokee, the t case from my comanche donor truck. My question is about the linkage. I cant get it to fit. I have the linkage from the Ax-15 and linkage from the donor which had an automatic. Do i need to modify something i dont know about? I couldn't find a answer anuwhere so i made a thread thatnks in advance.
JeepComanche89 is offline
post #2 of 3 Old 10-25-2012, 07:06 AM
97_4popper
1990 MJ Comanche
If you switched the tranny in your truck to the auto, the bracket that the linkage attaches to under the truck is slightly different. I converted my truck from auto to AX15 and ran into the same issue. The brackets between the 2 are offset slightly. Pull the bracket from the donor and switch them. There are 4 bolts under the carpet on the inside on the driver side of the tranny tunnel that hold the brackets.
Good Luck!
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 3 Old 10-25-2012, 07:11 AM Thread Starter
JeepComanche89
1989 MJ Comanche
I converted to ax-15 as well. I will take pictures today of what i have i may be missing something. Im not sure how the shifter handle links to the actual tab on the t case.
