Help with getting my tranny back in - JeepForum.com
post #1 of 13 Old 05-15-2014, 02:54 PM Thread Starter
Dedgar
1988 MJ Comanche
I recently got a mj with a blown motor, it also came with a 93 xj 4.0. As the mj came stock with a renix motor I kept my intake and exhaust and swaped the rest. Now that I am trying to get my ax15 put back in place I can't get it to slide all the way on. Am I not lining it up well enough or is there some small difference that is keeping me from finishing up? Any help would be great.
Dedgar is offline
post #2 of 13 Old 05-15-2014, 05:39 PM
Caish
1987 XJ Cherokee
Sounds like you have the clutch disc slightly mis-aligned, or you need to put the tranny into gear and turn the tranny slightly as your pushing it in to align splines to clutch disc.
Easy, cheap clutch alignment too, use a extension that or long bolt that fits in the pilot bushing, and then wrap mashing take around it till it fits snuggly in the clutch disc.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #3 of 13 Old 05-15-2014, 06:58 PM Thread Starter
Dedgar
1988 MJ Comanche
That was my first thought too, so after a week of waiting at the mailbox it showed up today and I aligned it. I can get spindle started into the clutch but it stops about an inch short of flush. Also I used the pressure plate, clutch and flywheel off the 88 motor, not sure if that matters.
Dedgar is offline
post #4 of 13 Old 05-15-2014, 07:46 PM
87MJTim
1987 MJ Comanche
What yr was the AX15 from? The trans input shaft sizes changed. The shaft size was larger on the early AX15s. The pilot bushing in the 4.0 maybe to small. It may need to be changed. I believe it was 93 or 94 that the changed occurred.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.2, AX15 (Formerly T5)
87MJTim is offline
post #5 of 13 Old 05-15-2014, 07:53 PM Thread Starter
Dedgar
1988 MJ Comanche
Pretty sure the tranny is the original so it would be a 88, how hard is it to change an input shaft?
Dedgar is offline
post #6 of 13 Old 05-15-2014, 07:57 PM
87MJTim
1987 MJ Comanche
The change in input shafts was from 91 to 92.
You want to change the pilot bushing. They're $5 - $6 from Rockauto.com. Be sure to search for one from an early model 4.0/AX15.
You can rent a bearing puller and slide hammer from many auto parts stores.
Edit:
You want the pilot bushing for the earlier AX15
Tim
87MJTim is offline
post #7 of 13 Old 05-15-2014, 08:12 PM Thread Starter
Dedgar
1988 MJ Comanche
Thanks for the info, I was figured there had to be something I didn't know.lol
Dedgar is offline
post #8 of 13 Old 05-15-2014, 08:16 PM
Caish
1987 XJ Cherokee
We put a tranny from a 90 model XJ in the sons 88 MJ that had a ba5/10 the pilot bushing was the same, but my 87 someone used a later model AX15 and it took me a few tries at the parts store to finally get one that worked.
Caish is offline
post #9 of 13 Old 05-15-2014, 08:23 PM
87MJTim
1987 MJ Comanche
The early AX15 (pre 92) had the same input shaft as the BA 10. When you use the later AX15 (or a 4.0 that was mated to a later AX15 with the earlier model) you have to change the pilot bushing.
Tim
87MJTim is offline
post #10 of 13 Old 05-29-2014, 10:16 AM Thread Starter
Dedgar
1988 MJ Comanche
Ok so I haven't had a lot of time to work on this with the new bushing until today, but I'm still having a problem getting the tranny in. I have the right pilot bushing but still can't get it to slip in the right way, I got some long bolts to help line it up with no success. Any suggestions? Should I use the flywheel off the 93?
Dedgar is offline
post #11 of 13 Old 05-30-2014, 05:40 AM
87MJTim
1987 MJ Comanche
The flywheel should remain with the engine. The 88 is Renix; a 93 is HO. The 93 would not work without a major wiring upgrade. Think CPS.
Can you tell where it is binding up? Is it the pilot bushing or is the clutch not lined up properly? Just asking for possibilities.
Tim
87MJTim is offline
post #12 of 13 Old 06-02-2014, 12:16 PM
Paradise XJ
1988 MJ Comanche
Have you removed the old pilot bushing AND re-installed the new? When I looked at the pilot busing on mine I couldn't tell that there was a bushing there until I did some digging. whatever you do don't use the bolts to "pull on" the tranny...it should slip right in if you have all the right parts & pieces installed correctly.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #13 of 13 Old 06-03-2014, 10:56 AM Thread Starter
Dedgar
1988 MJ Comanche
I got it back in now, everything was lined up right but the new brass bushing was so tight I had to use longer bolts to slowly pull the bell housing flush, it seems ok now just need to get the shifter back in and transfer case back on. Thanks for everyone's help!!
Dedgar is offline
ax15
