Hard starting problem, need help - JeepForum.com
post #1 of 11 Old 08-30-2012, 04:14 PM Thread Starter
87manche17
1987 MJ Comanche
Ok, Im having some wierd trouble out of my MJ. It takes it forever to start, it trys to start but to no avail. When it does start it runs perfect, and doesnt have any problems whatsoever. I have good fuel pressure, good spark, and air. But now when I unplugged my MAP sensor it tried to fire, and it fired up. I had to feather the gas pedal to keep it running, but it ran. So Im kinda wonderin if my MAP sensor is bad, or is thier something I havent though of.
87manche17 is offline
post #2 of 11 Old 08-31-2012, 02:39 PM
newfieZJ
I would think your fuel lines are draining back into your tank . Check valve Map sensor might have been plugged back in right after it was running ?
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 11 Old 08-31-2012, 04:50 PM Thread Starter
87manche17
1987 MJ Comanche
I have changed the battery for a new one and it starts, but im still having trouble. Because I have to press the gas pedal to get it to start.But once started its fine. WTF?
post #4 of 11 Old 08-31-2012, 06:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Gas pedal have to be pressed to the floor?
cruiser54 is offline
post #5 of 11 Old 08-31-2012, 06:42 PM Thread Starter
87manche17
1987 MJ Comanche
Yep, if I dont it will crank all day.
post #6 of 11 Old 08-31-2012, 07:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check the hose to the MAP sensor from the throttle body. Can't be crushed, crimped, cracked or split. Must fit tightly on both ends. Make sure the electrical plug to the MAP is seated tightly.
post #7 of 11 Old 08-31-2012, 08:28 PM Thread Starter
87manche17
1987 MJ Comanche
Ive checked it 3 or 4 times thier both connected fine. It woulndnt be faulty would it?
post #8 of 11 Old 08-31-2012, 08:36 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The MAP? Sure could be. I just always check the simple stuff first.
post #9 of 11 Old 09-01-2012, 07:09 AM Thread Starter
87manche17
1987 MJ Comanche
Ok thanks, I'll get back to ya when I change the MAP sensor.
post #10 of 11 Old 09-01-2012, 07:16 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Got a meter and know how to use it?
post #11 of 11 Old 09-01-2012, 10:01 AM Thread Starter
87manche17
1987 MJ Comanche
Ok now it only starts if its warm outside. If i try to start it in the morning, it will just crank and catch.
Hard starting problem with my 87 MJ 87manche17 XJ Cherokee Technical Forum 0 08-26-2012 07:37 PM
Hard starting YJBully XJ Cherokee Technical Forum 5 09-21-2010 08:11 AM
Hard starting 1996 Problem? 4.0H.O.XJ XJ Cherokee Technical Forum 3 12-10-2008 03:47 PM
Hard starting? lilseth0014 XJ/MJ Cherokee Non-Technical Forum 1 07-01-2008 09:24 PM
85 2.5L Hard starting problem/ no power RedJeepXJ XJ Cherokee Technical Forum 4 12-26-2002 06:16 PM
