Hard start....(HELP) - JeepForum.com
post #1 of 10 Old 04-24-2011, 06:13 PM Thread Starter
bravojmc
1987 MJ Comanche
Hi guys. Ok I've got a 1987 jeep comanche with a 4.0 auto. When I go to start my truck it cranks and crank and cranks before it starts. I've replaced spark plugs, cap, rotor, wires.... but I still does the same thing. Has anyone had this problem?
Get in sit down and shut the F#%* up!
bravojmc is offline
post #2 of 10 Old 04-24-2011, 09:47 PM
tbburg
Pretty common problem with all the XJs/MJs. Sorry, I don't have a fix for you. My MJ('88) does it when cold, but will start immediately when warmed up.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #3 of 10 Old 04-26-2011, 09:11 PM
Joshharris98xj
This just happened to me it's the relay switch close to your fuel pump but don't get me wrong it's NOT the fuel pump it's the relay an it's hard to get to so try this this is what I do and it fires up every time
-turn the key on for just about 2 seconds
-repeat on and off (not yet cranking) 2 to 3 times and it will prime the fuel lines then crank it should fire up
Joshharris98xj is offline
post #4 of 10 Old 04-27-2011, 06:03 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Could also be a faulty/weak CPS aka crankshaft position sensor. It can be tested easily with a meter.
cruiser54 is offline
post #5 of 10 Old 05-06-2011, 03:57 AM
grabber1000
1986 MJ Comanche
CPS does not have anything to do with starting.. only running.The quickest way to trouble shoot is first check injectord with noid light( 5$ @ Amazon) That will let you know if all signal to ECU are their, Then fuel Pressure. Work on this problem for 6 months.. Down to fuel regulater
It's slow, heats up like a *****, probably draws more amps than a locomotive and sounds like a bucket of bolts while running but hasn't failed YET.
97 TJ 3" Lift
86 MJ Long Bed 8.5" Lift
89 MJ Short Bed 4.5" Lift
grabber1000 is offline
post #6 of 10 Old 05-06-2011, 04:16 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Gonna have to disagree here. A weak CPS CAN cause long craning times as it generates an AC voltage signal that gets stronger the longer and faster you crank the engine over. When it finally starts, the added engine RPM helps to generate the stronger signal and it keeps running. Not saying it's your problem but wanted to straighten this out.
If you have a manual trans, worn clutch material can accumulate on the CPS and cause your exact symptoms.
post #7 of 10 Old 08-16-2013, 07:45 PM
OldDoom
1989 MJ Comanche
Agree with cruiser 54. CPS fixed the hardstart problem in my 89 with a 4.0L six.
OldDoom is offline
post #8 of 10 Old 08-16-2013, 08:11 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I know this thread is now revived from the dead, so I'll post the CPS testing procedures for Renix.
There's also 25 write-ups in the link in my signature on mostly REnix tips.
Renix CPS Testing and Adjusting
Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark.
Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad.
The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isnít generating enough voltage to trigger the ECU to provide spark.
Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It wonít start with the CPS disconnected.
You should get a reading of .5 AC volts.
If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! Thatís a definite no-start condition. Best to buy your CPS from Napa or the dealer.
Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. Itís worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off.
A little trick for increasing the output of your CPS is to drill out the upper mounting hole to 3/8Ē from the stock 5/16Ē, or slot it so the CPS bracket rests on the bell housing when pushed down. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts.
Revised 01-26-2013
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
post #9 of 10 Old 08-17-2013, 02:00 PM
Soldier905
1988 MJ Comanche
I had same issue and it turned out to be the fuel pump relay . It ran great after i replaced it
Soldier905 is offline
post #10 of 10 Old 08-17-2013, 09:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Only testing narrows it down. These fixes are not "one size fits all".
88 4.0L intermittent no start/hard start nglass1219 XJ Cherokee Technical Forum 12 01-25-2012 07:39 PM
Hard to start/No start after stalling in gear nbaker XJ Cherokee Technical Forum 10 02-26-2011 05:09 PM
Hard Start, No Start, Rough Idle Hillbillydeluxe XJ Cherokee Technical Forum 11 09-19-2008 12:11 PM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 08:18 PM
Hard start, every day its taking more and more cranking to start. Xride XJ Cherokee Technical Forum 8 11-27-2006 08:20 AM
