good old 4.0 - JeepForum.com
post #1 of 6 Old 03-21-2008, 11:13 AM Thread Starter
kinkydoints
1991 FSJ Wagoneer
good old 4.0
I have been working to get this 1991 4.0L wagoneer limited to run with out squeeling from the serpintine belt hitting on the timing chain cover. I can see it . I have changed waterpump , alltinater, ideler pully,and belt. this is the old style that has the adjuster under the powersteering pump. It seems like the belt is just too close to the timing chain cover at the engine were it comes off the cluchfan pully and to the engine main vibration damper pully? Im looking at the cluchfan pully now but that looks like a dealer part or junkyard. there seems to be no adjustment in the alltinators mount just the 2 bolts that hold it in place...Is there any way I missed something. I wondering if I file down the alt. mount on the alt and add a spacer washer to move the pully out about 2mm. Im just guessing!
kinkydoints is offline
post #2 of 6 Old 03-21-2008, 08:05 PM
B_Mabus
1994 XJ Cherokee
I had this happen on my Cherokee. The harmonic balancer is going bad. Look under it and see if the Harmonic Balancer is walking back and rubbing on the cover. I had to get a new one good luck with it. I didnt have a squeal of the belt just that the harmonic balancer was rubbing on the timing chain cover.
'89 XJ 183,xxx BLACK with olive drab....parts jeep
'90 XJ 177,xxx WHITE....sold
'90 XJ 153,xxx RED...wip
'94 XJ 145,xxx WHITE...current ride
Nothing runs like a Renix
B_Mabus is offline
post #3 of 6 Old 03-22-2008, 09:02 AM Thread Starter
kinkydoints
1991 FSJ Wagoneer
ya well this old engine has 165,000 miles but still goes good. Ill check this out thanks!
post #4 of 6 Old 03-23-2008, 12:02 PM Thread Starter
kinkydoints
1991 FSJ Wagoneer
Checked that walking balancer out that was the trouble gave it a little push for now worked for a quick fix.
were did you get your Vibration Damper pully at? dealer or parts store? junk yard?
post #5 of 6 Old 03-24-2008, 09:55 AM
carnuck
1984 J-Series Truck
you can get them new from NAPA.
carnuck is offline
post #6 of 6 Old 03-31-2008, 11:48 AM Thread Starter
kinkydoints
1991 FSJ Wagoneer
Thats it ! the squeek! is gone.
any Idea about a head gasket change ? as far as parts needed, do I need to change the injecter seals, this motor has the mpi . Im guessing both intake and exhast gaskets, valve cover gasket
4.56 with 35s good or no go? pfcstone777 XJ Cherokee Technical Forum 9 03-26-2009 02:07 PM
Defrost only good but not good samiam2714 XJ Cherokee Technical Forum 1 02-07-2008 01:24 AM
that's not good ehall XJ Cherokee Technical Forum 0 12-24-2007 08:47 PM
good PSI? slrmacro XJ Cherokee Technical Forum 8 12-09-2007 07:17 PM
Looking good? The_Other_One XJ Cherokee Technical Forum 10 03-11-2006 09:54 AM
