Going SOA, what springs will I need - JeepForum.com
post #1 of 7 Old 02-11-2012, 12:37 PM Thread Starter
offroading.net
offroading.net's Avatar
2007 WK
We have NO MJ stuff in the UK, so its XJ or ZJ/WJ only stuff available for me. I am fitting a set of WJ diesel axles under my MJ (because I have a set & they are 3.91 diffs & variloks).
So if I will be going SOA & using an XJ rear spring what amount of lift spring will give me a 4" lift in the back with my setup? (a D44 has a 2-5/8"OD tube)
thanks
Steve Wright
'07 Grand Cherokee Overland CRD
'16 Renegade Limited, Wifey Wagon
Previous Jeeps- 8 XJs, 3 KJs, 3 WJs, 2 TJ's & an MJ
offroading.net is offline
post #2 of 7 Old 02-11-2012, 03:47 PM
willi2ds
1988 MJ Comanche
I swapped in a 8.25 and just used the stock leaves, got about 6" of lift
willi2ds is offline
post #3 of 7 Old 02-11-2012, 06:52 PM
Garvin
1986 MJ Comanche
The XJ leaf springs won't work, you're pretty much stuck with the MJ springs and you can either run them straight stock or make a bastard pack out of them. When I did my SOA, I just use my stock springs. Mine were sagging a little so when I swapped the 8.25 and doing a SOA only netted me 4.5" over stock. A brand new spring will net about 5.5" going SOA. Since you're swapping axles...old axle centerline to bottom of leaf perch + new axle centerline to top of leaf perch will be your lift.
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #4 of 7 Old 02-12-2012, 03:23 AM Thread Starter
offroading.net
2007 WK
Will an XJ add a leaf fit in an MJ spring pack? I think I will be making a leaf pack up.
Steve Wright
post #5 of 7 Old 02-12-2012, 08:01 AM
Garvin
1986 MJ Comanche
An AAL from an XJ will net you no lift.
...RIP...
Garvin is offline
post #6 of 7 Old 03-18-2012, 01:13 AM
carnuck
1984 J-Series Truck
AAL in an MJ pack will ride like a rock if you SOA
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #7 of 7 Old 03-22-2012, 02:42 PM
OriginalNVMJ
1992 MJ Comanche
MJ rear springs
Check out General Spring, Hellcreek Springs & Deaver Spring
OriginalNVMJ is offline
Stock Springs With AAL or Dodge Dakota Springs? Skatertony528 XJ Cherokee Technical Forum 7 11-16-2008 05:56 PM
Medium Duty springs or HD springs w/my BB 2" lift mrtosh XJ Cherokee Technical Forum 6 09-16-2008 10:23 AM
Front Springs and Lift -- ZJ V8 and/or F150 springs Question XJ2000 XJ Cherokee Technical Forum 5 01-03-2008 11:51 PM
'99 XJ: can I replace stock springs w/Up Country HD springs? DennisT XJ Cherokee Technical Forum 6 12-30-2005 10:57 AM
Summit racing procomp rear springs and carquest hd springs lift? bluexj1996 XJ Cherokee Technical Forum 1 04-07-2005 01:16 AM
