Get your stock specs here!
| Truck-Lite's New LED Headlamp Series | NEW! Poison Spyder RockBrawler BFH Bumpers! | Poison Spyder BFH Rear Bumpers |
#46 | ||
Comanche Kemosabe
Main rig under screen-name... '96 XJ Country (pearl white) 2WD, 4.0L HO I6, AW4. Daily driver. '98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project. Gone, but not forgotten: '88 MJ Pioneer, '94 ZJ Limited, '85 CJ7, '98 ZJ Limited Blue Jeep Club Member #113 |
#47 |
The horsepower and torque ratings that you have for the 2.1L Turbo Diesel are wrong also. The 2.1L Turbo Diesel has 85 hp and 132 ft lb of torque.
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed Blue Jeep Club Member #123 Easy to be a truck. Hard to be a Jeep. Last edited by 1986Comanche; 09-19-2005 at 02:22 PM.. |
#48 | ||||
This is incorrect also. Not just 90-92 have the height sensing proportioning valve. My 1986 Comanche has the valve and I have a 1987 and it has it also and it's height not heigh. Quote:
This should say 87-90. The 4.0L I6 didn't come out until 1987. Quote:
This should say spring under axle design not ubder.
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed Blue Jeep Club Member #123 Easy to be a truck. Hard to be a Jeep. |
#49 |
1986Comanche, I don't ubderstand your reply
Blue Jeep Club Member #124 -1989 Comanche - Pioneer, LB, 4.0 I6 / BA10 / NP231 / D44 f&r w/Eaton E-Lockers & 4:56 gears Comanche build-up @ http://comancheclub.com/forums/viewtopic.php?t=8051&start=0&postdays=0&postorder= asc&highlight= |
#50 | |
#51 |
Comanche Kemosabe
ah, sorry guys for the slow response...edited.
Looks like I was a sorry speller and didn't even know what motor I had under my hood Thanks 1986Comanche
#52 | ||||||||||||||||
Just a few pointers:
Also, the "uni-frame" is stronger than an XJs. Quote:
short bed 2wd=113.1 4wd=112.9 long bed 2wd=119.6 4wd=119.4 Quote:
Oh, and the Dana 35 c-clip used 89+. Quote:
Overall length was 179.3" for shortbeds, 194.0" for longbeds Overall curb height was 63.7" for 2wds, 64.7" for 4wds Track width was 57" with the 15x6 rims, 58" with the 15x8s Body width at the rear flares was 71.7" Length of inside of box at the floor was 73.7" sb and 88.5" lb Width of box at the floor is 55.3" for both sb and lb Width between wheel wells is 43.8" Box depth is 16.4" Any other dimensions you'd like? Curb weight for the 2wd short bed was 2912 4wd sb was 3076 2wd lb was 2959 4wd lb was 3141 Payload for stock MJs is 1475 lbs (1200 for 86), Metric Tonne was 2205 lbs. The maximum tow rating an MJ was ever given was 5000 lbs (4.0L required). 2.5Ls seem to have been limited to 2000 lbs and 2.8Ls were 4200. I cannot find any rating listed for the stock bumper. Every brochure mentions a class 1,2,3 hitch needs to be installed for towing. Hope this helps! ![]() Jeep on! --Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc. Also an 86 MJ Metric ton and 2 '90 MJs Projects/wheelin' pics: picturetrail.com/petermontie My email: petermontie@hotmail.com ComancheClub.com/forums |
#53 |
I did some hunting around and I'm fairly confident that NP-228 equiped 1986 MJs came without the CAD front axle.
Jeep on! --Pete
#54 |
Pete,
I have seen them both ways in the Pick aparts around here. I dont think there is any hard rule on what front axle it got. I have also seen it with CV axles instead of u-jointed ones.
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it [url]http://independent4x.com/generic67.html[/url] [url]http://community.webshots.com/user/cj7xjmj[/url] If you have to ask why... Its a truggy thing and you wouldn't understand |
#55 |
Comanche Kemosabe
Thanks Pete M for everything! There are a couple of small things that I found otherwise at junkyards and stuff with "replacement documentation" to confirm the parts on them were still stock, but other than that, your info helped alot! Some of the things that you posted I just quoted up as I can't really manage it in cleanly with the specs, however, the quotes do imply how they affect what's already typed down as stock.
Again, much appreciated
#56 | |
Hmm... How can you find all this info. You must have the stock manual/owners book |
#57 | |
I feel the truth is way more important than anyone being right or wrong. Heck, I've found mistakes in the brochures before. I also use my 87-90 Jeep parts manual and the search feature at car-part.com Lots of good info there. The 4.56 ratio option was considered fantasy by many, but now it's (mostly) accepted as fact. Next time someone sees a non-CAD MJ, take note of the VIN number, engine/tranny/t-case combo and the tag on the diff cover as well as any extraneous parts that would indicate a prior CAD (like the associated vacuum lines). It's fun discovering new clues! ![]() Also, I found my 87 brochure and the 4.0L was rated for 173 that year. Jeep on! --Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc. Also an 86 MJ Metric ton and 2 '90 MJs Projects/wheelin' pics: picturetrail.com/petermontie My email: petermontie@hotmail.com ComancheClub.com/forums Last edited by Pete M; 11-11-2005 at 07:40 PM.. |
#58 | |
Comanche Kemosabe
And I didn't find all that info on the first page. When I first started it, I just modified the Cherokee stock specs, edited what I already knew, then opened the thread up for other information that I didn't know about so I could add it on. ![]()
#59 |
This is a great thread and I really appreciate it since I am a new MJ owner. But I do have a couple questions. Can you expand on the different packages and let me know what the differences between them were? I am also curious as to what our trucks cost new...does anyone have a price list?
#60 |
The names generally referred to a trim level with the Base having fewer standard items and the Eliminators and Laredos having just about everything. Lots of features could be ordered separately from the trim pachages too, so not every base model you see will have a completely spartan interior.
Jeep on! --Pete
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
