#31 | ||
I could use an extra 25 ponies in my TJ ![]()
'01 TJ 60th Anniv. Ed. "6 cylinders of gut wrenching torque" |
#32 |
"Also, MJ's through 90-92 are equipped with a heigh sensing proportioning valve that is used to change the bias of the brakes if the bed had a load in it."
My 88 eliminator has this valve...
[COLOR=Navy]97 TJ Sport [/COLOR] 4.0 5spd 4" pro comp lift 2"BL w/ 33's, k&n, poweraid spacer, dynamax [COLOR=DarkRed]88 MJ Eliminator [/COLOR] 4.0 AW4 / Rusty's intake, borla header and muflr, convrtd. to open 3- core [COLOR=Navy] 00 XJ Sport [/COLOR] 4.0 Aw4/231 , STOCK |
#33 |
My 1986 Comanche has a height sensing proportioning valve also.
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed Blue Jeep Club Member #123 Easy to be a truck. Hard to be a Jeep. |
#34 |
I just picked up a 87 Comanche, it also has the height proportioning valve. Also just read the tag on my front axle and it reads 3 54 46-13 indicating my 2.5L / 5 spd has 3.54 gears which I don't see on the list, So either my axles have been swapped or ?
. Anyway the information is great, thanks!
[COLOR=Blue]93' Cherokee Country[/COLOR] [COLOR=Blue]8.8 Rear Diff w/ discs, 3.73 gears [/COLOR] [COLOR=Blue]Rough Country 4.5" lift and 31" Pro-Comp MT's[/COLOR] |
#35 |
jpringlemn, some of the Comanches came with 3.54 gears, so I would say your axles are original.
#36 |
plse keep yer eyes open for the production numbers on the metric tonne units, especially 1990
90 metric tonne MJ |
#37 |
Jeep 4.0L info
The difference between the 4.0L and the 4.0L H.O. is a combination of cylinder head design, fuel injection type(from throttle body - renix- to Multi Point Injection), and computer tuning.
The 4.0L (standard) ended production in 1991, when the 4.0L H.O. came out. Though the "high output" was later dropped, it is still the high output version. As time went on, it's power increased from 180 to 190hp, in all but the wranglers. Due to its more restrictive exhaust the YJ and TJ, took more fine tuning over the years to develop 190 hp. I don't remember the years that everything took place, but you can probably find it online. As far as I know, no 4.0s came from the factory with more than 195hp. I spoke with a jeep engineer who mentioned in some of their test, they had the 4.0L getting 300 hp by playing with computer tuning, but the MPG suffered greatly. Sometime around the 99 year model the 4.0 came with a "dual plane" intake, instead of the traditional straight runner. This occured when coil packs replaced the distributor. I believe this combination yielded more torque in the grand cherokee. --------------------- Quote: Originally Posted by countryjeep Wait a second...the 4.0L H.O. shows as being 190hp on the Car & Driver review of the Jeep Cherokee. These specs compy with Comanche specs also. The 99' and up 4.0L's stayed the same, with the exception that the regular 4.0L's above 99' were upgraded to 190hp and the 4.0L H.O.'s were upgraded to 215hp. Or did they miscalculated horribly? Did they still make the "H.O." after 99? I thought that was discontinued prior I could use an extra 25 ponies in my TJ __________________
. . . end transmission . . . |
#38 | |
Comanche Kemosabe
But I'm gonna see if I can find an area on the first page for this info. Again, thanks
Main rig under screen-name... '96 XJ Country (pearl white) 2WD, 4.0L HO I6, AW4. Daily driver. '98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project. Gone, but not forgotten: '88 MJ Pioneer, '94 ZJ Limited, '85 CJ7, '98 ZJ Limited Blue Jeep Club Member #113 |
#39 |
I have a stock Comanche Laredo 1988, (export model to Europe maybe?)
But here is my spec: L6 EFI Engine, Auto trans Dana30 in front and Dana44 in rear, 3.55 gear Power Window Power Door Lock Power Steering Tilt Steering Column Power Comfort Switch Height Sensing proportion Valve Bucket Seats AM/FM Radio "Jeep" No AirCondition No Speed Control No Rear Window with opening (only one piece) No center consol, only consol for gear shifters
"If everything seems under control, you're just not going fast enough" - Mario Andretti Jeep TJ Wrangler 4.0 Sahara 2006 Jeep TJ Wrangler 4.0 Sahara 2004 Jeep CJ5 1977 |
#40 |
based on the first post, im wondering if my guesses are correct.
I have an 89 Eliminator 2wd. It has a 4 liter and a 5 speed. Am I correct to assume I have .307 gearing and an AX15? Also, whats the scoop on the Peugot trannies that were used? What applications did those end up in?
2002 WJ Limited 4.7L Quadradrive Built to serve rally racing in communications, crash recovery and medical response. My exhaust clip http://www.youtube.com/watch?v=M_8aTOEbRrc |
#41 | |
#42 | |
Comanche Kemosabe
As for the Peugot trannies, they mostly ended up in the 86' models I think. If any ended up in 87', it must've had to be the early part of the year in the bare-bone models.
#43 | |
#44 |
Mine is an 89 and
it's got it. They switched to the AX15 sometime late in 1989.
Blue Jeep Club Member #124 -1989 Comanche - Pioneer, LB, 4.0 I6 / BA10 / NP231 / D44 f&r w/Eaton E-Lockers & 4:56 gears Comanche build-up @ http://comancheclub.com/forums/viewtopic.php?t=8051&start=0&postdays=0&postorder= asc&highlight= |
#45 |
The Peugeot transmission was not used in 1986. The AX-4 (4 speed) and AX-5 (5 speed) are Aisin transmissions. The 2.8L GM V6 which was only offered in the 1986 Comanche was not available with a 4 speed manual tranmission. It was only available with the 3 speed automatic and the 5 speed manual. The 4 speed manual was only available with the 2.5L I-4. Also the 4.0L I-6 was not available until 1987. It replaced the 2.8L GM V6. The 4.0L was only application for the Peugeot BA-10/5 (5 speed) transmission. The Peugeot BA-10/5 was used until 03/09/89. The AX-15 was used from 03/03/89 which means there were 7 days when they built the Comanche with either transmission.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
