Fusible Link - JeepForum.com
post #1 of 9 Old 07-15-2013, 01:30 PM Thread Starter
thug3
1989 MJ Comanche
Fusible Link
I have an 89 Comanche 2WD 4.0 5 speed. Just replaced my fusible link for the second time in 2 weeks. upon investigation found positive battery cable to the starter completely melted. Don't know what caused this? When the link blows it kills the engine but everything else still works. Please help. Thanks
thug3 is offline
post #2 of 9 Old 07-15-2013, 08:51 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you replaced that melted cable? Is your starter covered in oil?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 9 Old 07-16-2013, 04:18 AM Thread Starter
thug3
1989 MJ Comanche
No not yet. I want to find out why it melted first so it doesn't melt a new one. And no, the starter isn't covered in oil. Maybe corrosion inside battery cable? Gonna check that Friday.
thug3 is offline
post #4 of 9 Old 07-16-2013, 05:24 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Got an ohm meter? Multimeter? Check the resistance between the ends of that melted cable.
post #5 of 9 Old 07-16-2013, 05:37 AM Thread Starter
thug3
1989 MJ Comanche
Yes I do. I will check that. Also have a new cable to compare it to.
thug3 is offline
post #6 of 9 Old 07-19-2013, 09:28 AM Thread Starter
thug3
1989 MJ Comanche
Checked the old cable and got same readings as new cable. Someone suggested the starter shorting out, but I haven't had any problems with it . Not dragging or anything. Once it starts the starter is out of the loop right? The only cable I haven't removed is the smaller one from the starter relay to the altenator. But it looks fine from what I can see of it.
thug3 is offline
post #7 of 9 Old 07-21-2013, 01:19 PM Thread Starter
thug3
1989 MJ Comanche
I replaced the fusible link with 8 gage wire and a 30 amp thermal circuit breaker. Can't find anywhere that says what the amperage is for the fusible link. Worried I might have too high amp circuit breaker.
thug3 is offline
post #8 of 9 Old 07-21-2013, 01:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I used to have that info from Jeep but lost it in a computer crash. Working on getting it again.
I had the info gauge vs amp rating. This is all I have now.
Which link blew?
post #9 of 9 Old 07-21-2013, 11:19 PM
gus7
ok get vom over the voltage and ohns if you have bad grounds, your alt can over charge - charging system needs looking too .....
gus7 is offline
