fuel injector issue - JeepForum.com
post #1 of 9 Old 02-14-2005, 02:06 PM Thread Starter
rustybottoms
fuel injector issue
Hey fellas, i have an MJ and a leaky fuel injector. I also think that my injectors maybe clogged. Anyone have any of these issues? would the injector leak due to worn o-rings? can my injectors be cleaned? should they be replaced? any assistance would be greatly appreciated.
1988 Comanche Chief 4.0 4X4 stick
109k miles on it
It's a piece of junk, but I love it!...most of the time.
rustybottoms is offline
post #2 of 9 Old 02-14-2005, 05:07 PM
mdfowler
I've had issues with my previous XJ with this topic. Initially, i changed the o-rings in the fuel rail, and noticed a decrease in leaking, but it still leaked. Upon further inspection, i noticed at the front of the fuel rail there is a fuel pressure regulator, that has a vacuum line attached to it. I solved my problem when i replaced that vacuum line, it was plugged from something and not allowing the regulator to recieve any vacuum.
I'm not sure about the cleaning part... know there are a lot of products on the markey, but not certain if any are really worth buying.
My e-mail is
... i don't check the one that this forum is attached to, and it will not let me change to a Yahoo e-mail.
mdfowler is offline
post #3 of 9 Old 02-14-2005, 08:59 PM
89xj4x41
89xj4x41's Avatar
I had 2 leaky injectors and i was goin to just replace the o-rings but i heard that just replacing the injector is the way to go so thats what i did. If you wanna clean them, take some injector cleaner and add it to full tank. You want to also check your fuel regulator and attached vacume hoses like Mdfowler has noted. Good Luck
Nick
1989 jeep laredo - 5spd - 4.5 (3.5 RE super flex with 3/4 inch spacers up front and RE 1.25 shackles rear) - Tom Woods CV driveshaft - Tom Woods SYE kit - 31" X-Terrains -surco roofrack - fram air hog filter - pro comp adjustable track bar
Coming soon: chysler 8.25, 4.56s
89xj4x41 is offline
post #4 of 9 Old 05-08-2013, 05:38 PM
Jeepuzzled
1989 MJ Comanche
Tutorial for replacing injectors
I am planning to replace all the injectors of my 1989 Comanche 4.0L ( Base model), but am looking for an online tutorial for this. This forum has a great tutorial for a 1995 Sport 4.0L, but the engine looks slightly different from my '89. The fuel connections are different than mine, so I can't follow that tutorial exactly. Any tips? Thx.
Jeepuzzled is offline
post #5 of 9 Old 05-08-2013, 06:09 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
REPLACE them with an upgrade injector that has 4 holes in the tip. Your factory Renix injectors are prone to leaking at a seam and causing engine fires.
Here's the tutorial you asked about.
http://www.cherokeeforum.com/f51/inj...ap-4-0l-92149/
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is online now
post #6 of 9 Old 05-10-2013, 02:17 AM
Jeepuzzled
1989 MJ Comanche
Thanks. I previously referenced that guide for the 95 Sport, but it has a slightly different setup than a Comanche. The biggest ankle biter is the Quick Connect fuel lines that require replacing clips, O rings, and spacer for each connection whenever you pull it apart. The old Quick Connect Repair kits are next to impossible to locate even from Jeep dealers.
post #7 of 9 Old 05-10-2013, 05:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
CRB212305 is the kit. .
O-rings are 730-5017 at Napa.
post #8 of 9 Old 05-10-2013, 01:15 PM
Jeepuzzled
1989 MJ Comanche
Morris 4 x 4 has the similar kit for much less. Fuel/Oil Cooler Line Repair Kit # 83502745 5/16" $8.99 vs. the NAPA CRB for $18.73. Given that you need one kit for every fuel line reconnection, the cost adds up quickly.
post #9 of 9 Old 05-12-2013, 06:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's why I just use the o-rings. Just remember the plastic spacer goes between the o-rings.
fuel injector? skip11and1 XJ Cherokee Technical Forum 3 05-27-2009 08:36 AM
ECU/ECM Fuel Injector Help LokiCDXX XJ Cherokee Technical Forum 0 11-10-2008 03:50 PM
fuel injector/fuel rail question LeeBee XJ Cherokee Technical Forum 4 11-16-2007 12:02 PM
Bad Fuel Injector Aqua436 XJ Cherokee Technical Forum 3 11-06-2005 01:06 PM
fuel injector issue rustybottoms XJ Cherokee Technical Forum 4 02-14-2005 05:48 PM
