Fuel Injector FLow Rates Chart - JeepForum.com
post #1 of 1 Old 09-14-2014, 07:05 AM Thread Starter
hillbilly51
1988 MJ Comanche
This may be handy to someone
http://users.erols.com/srweiss/tableifc.htm
steve
You will note that the flow rates for Bosch injectors are rated in n-Heptane verses gasohol (E85) for other makes of fuel injectors.
I copied this from www. racetronics.biz for converting Bosch injectors to their rated flow in (E85) Gasohol.
"Injector flow rates are based on testing with n-Heptane test solvent (0.6855 g/ml). U.S. EPA emission test gasoline 40CFR86.113 (0.735g/ml) flows in most common injector designs at about a 3 to 4% higher rate than n-Heptane. A ratio of 1.035:1 can be used when converting the flow specifications above".
hillbilly51 is offline
