Front Springs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Front Springs
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 12-15-2005, 04:04 PM   #1
Car RamRod
Front Springs
my ds front spring it cracked. Im gonna try to get one tonite, is it the same as the xj uses?
1986 Comanche, 4x4, 2.8l v6
1989 Mustang LX Coupe, h/c/i, bolt ons, 5lug
have to break in engine and trans, then hitting E-town and a dyno
Car RamRod is offline   Reply With Quote
Unread 12-15-2005, 04:21 PM   #2
CanadianJeep86
everything in front of the fire wall is the same as XJ's. yes they will fit because I've had to do it on mine, they are the exact same
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights.
1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3".
1986 2dr XJ, 2.8, 5 speed, Bushbar,
1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen*
1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven*
1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven*
CanadianJeep86 is offline   Reply With Quote
Unread 12-15-2005, 05:08 PM   #3
Car RamRod
I thought so but wasnt sure....thanks
Unread 12-15-2005, 08:10 PM   #4
Car RamRod
another question; did the the xj use the same springs all the way up to 01?
Unread 12-15-2005, 09:27 PM   #5
CanadianJeep86
I'm not 100% sure on that but as far as I know they never really changed anything underneath except for the t-case and axles. Pretty sure everything is the same. Hopefully somebody with a newer XJ will pipe up and shed some light on that question.
Unread 12-15-2005, 09:56 PM   #6
randyscj
1990 MJ Comanche
they are all the same
1990 Comanche Eliminator, short bed, 4x4, 351W V8, 5spd, 8-9" lift, 4" YJ front leafs, D60's, 5.13's, Spartan front, Detroit rear, 16x10 wagons, 39.5" Iroks, JCRoffroad front bumper, TJ flares
Pics-http://smg.photobucket.com/albums/v2...che/?start=all
randyscj is offline   Reply With Quote
Unread 12-15-2005, 09:57 PM   #7
DirtyCommanche
Apparently 'up country' XJs came with springs that are an inch taller.
But with sag, it's not going to matter.
When getting springs, try to get a set off a newer XJ, as they'll probbaly have less milage on them and not sag/lean.
DirtyCommanche is offline   Reply With Quote
Unread 12-15-2005, 10:02 PM   #8
randyscj
1990 MJ Comanche
O yeah, i forgot about the Up Country. Sorry
Unread 12-15-2005, 10:07 PM   #9
DirtyCommanche
Well, it might not even be true. I've never seen it verified. However, there's a XJ in the yard here with longer than normal sway bar links, that just might be the elusive up country. I'd pull the springs, but I don't care that much.
