Flat towing 89 Comanche with AT - JeepForum.com
post #1 of 5 Old 03-16-2008, 02:48 PM Thread Starter
Metalwkr
1989 MJ Comanche
Can you flat tow a 89 Comanche 4X4 with AT? If so any particular procedure for doing so? Any info would be appreciated..
Metalwkr is offline
post #2 of 5 Old 03-16-2008, 05:03 PM
1996xj
2005 WK
If you do, put the TRANSFERCASE in neutral, that way both driveshafts will be disconnected from the transmission.
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline
post #3 of 5 Old 03-16-2008, 05:59 PM
Pete M
1988 MJ Comanche
Personally, I unbolt the driveshaft from the rear axle and securely strap it up under the Jeep (you can't just pull it out or fluid can leak out the back of the t-case).
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 5 Old 03-17-2008, 05:45 PM Thread Starter
Metalwkr
1989 MJ Comanche
Thanks...I appreciate it!
Metalwkr is offline
post #5 of 5 Old 03-20-2008, 11:58 PM
carnuck
1984 J-Series Truck
trans in park and tcase in neutral unless it's a NP207 (front/rear are locked together in neutral)
carnuck is offline
Flat towing a XJ jeepmann45 XJ Cherokee Technical Forum 6 10-16-2009 09:53 PM
Towing a 88 comanche Nightcon777 MJ Comanche Technical Forum 2 08-28-2009 01:51 AM
Flat towing a YJ ggjeep XJ Cherokee Technical Forum 8 02-21-2009 08:14 AM
Towing with XJ - Flat tow or dolly tow? slowerisfaster XJ Cherokee Technical Forum 8 04-06-2008 12:12 AM
Flat Towing LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 17 08-08-2007 05:46 PM
