Flat Towing 1992 Comanche -Manual 5 speed RWD - JeepForum.com
post #1 of 8 Old 08-07-2012, 11:43 AM Thread Starter
Olele
1992 MJ Comanche
I posted this in the Cherokee Forum by mistake, so here it is in the proper forum.
I recently acquired a well kept 1992 Jeep Comanche pick-up truck. It is a short bed, 2 wheel rear drive with a 5 speed manual transmission. It has the 4.0 liter, 6 cylinder engine. I would like to tow it with all 4 wheels on the ground behind my class A motorhome.
I do not know anyone that has the same vehicle, and all the opinionated experts on various web sites continue to contradict each other over whether this vehicle can be flat towed. Even some of the special interest Jeep user groups contradict each other. Some say yes, some say use a dolly, some say trailer, some say disconnect the drive line, etc.
I can't believe that this is even a question with these 20 year old manual transmission, 2 wheel drive Comanche (1986-1992) / Cherokee (1984-2001) / Wagoneers (1984-1990).
Common sense would indicate that as long as the manual transmission is placed in neutral, and the ignition position is set to allow the steering wheel to turn freely, I should be good to go - as long as I have a good base plate, tow bar, safety cables/chains, and lights.
Olele is offline
post #2 of 8 Old 08-07-2012, 05:44 PM
automan2164
1986 MJ Comanche
Straight from the horses mouth, 1992 Service manual:
And '86 since I had it laying around:
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #3 of 8 Old 08-07-2012, 06:11 PM Thread Starter
Olele
1992 MJ Comanche
This is why it seems confusing. The 1986 says OK, but start up and place in 2nd every 200 miles - 1992 says disconnect driveline?
Olele is offline
post #4 of 8 Old 08-07-2012, 06:59 PM
automan2164
1986 MJ Comanche
Different transmissions, and/or people failing to do the 200 mile thing, leading to roasted trannies, leading to warranty and repair claims, leading to a change in policy.
Rob
post #5 of 8 Old 08-07-2012, 07:06 PM
DeejayZeejay
1994 ZJ
I would.
Jeeps 4 Life!
DeejayZeejay is offline
post #6 of 8 Old 08-07-2012, 08:21 PM Thread Starter
Olele
1992 MJ Comanche
Even the 1986 is a little confusing. States you can tow it 4 down in neutral, but stop at 200 miles and run it in 2nd gear (I assume with clutch in), then resume towing in "high gear", even though the first 200 miles were in neutral???
Olele is offline
post #7 of 8 Old 08-07-2012, 08:42 PM
automan2164
1986 MJ Comanche
Read it again. The second column at the top states "Additional Towing Information" and the first sentence starts with "To ensure complete lubrication of all transfer case components..."
Looks like in '86 with either transmission, put it in neutral and go.
In '92, they want you to pull the shaft. Which in itself, isn't really all that much of a bear to do. 4 bolts on a stock MJ, and you have the shaft out.
Rob
post #8 of 8 Old 08-08-2012, 06:23 AM Thread Starter
Olele
1992 MJ Comanche
Ah... When all else fails - read the instructions (carefully). Thanks again.
Olele is offline
