feels like I'm hauling, and not in a good way - JeepForum.com
post #1 of 14 Old 12-08-2012, 10:59 PM Thread Starter
Rican142
One day I'm driving along and all of a sudden my truck sounds like I'm flooring it(when I'm actually just tapping the gas) and it feels like I'm towing 5 more comanches behind me, as well as some noise coming from the closest part of the exhaust manifold as well as a sort of crunching sound from the tranny, as well as some type of oil dripping from the tranny between the bell housing and that plate in front of it ( might just be the rear main seal or tranny is finally going)
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 14 Old 12-08-2012, 11:56 PM Thread Starter
Rican142
Buddy of mine told me im loosing oil pressure. How do i check that
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #3 of 14 Old 12-09-2012, 06:47 AM
97_4popper
Sounds like the auto tranny is giving up the ghost. I assume auto.
I just checked your profile and it says BA10. So, scratch that.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #4 of 14 Old 12-09-2012, 06:48 AM
97_4popper
Clutch giving out? Slipping badly, maybe.
My build thread:
post #5 of 14 Old 12-09-2012, 07:38 AM Thread Starter
Rican142
Yeah, its a manny, and its a new clutch.
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 14 Old 12-09-2012, 08:41 AM
97_4popper
If you are having major oil leaks, it is possible that the oil has coated your new clutch nicely and making it slip.
Guessing.
My build thread:
post #7 of 14 Old 12-09-2012, 04:50 PM Thread Starter
Rican142
But its shifting into gear like normal. It's just not giving me that same pull that it used to
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #8 of 14 Old 12-09-2012, 07:09 PM
97_4popper
To test if it is slipping, going slow like 1st or second gear speed, put it in 4th and floor it.
If the engine revs but you don't gain speed, then your clutch is slipping.
My build thread:
post #9 of 14 Old 12-09-2012, 11:12 PM Thread Starter
Rican142
What do I do to correct this?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #10 of 14 Old 12-10-2012, 06:19 AM
97_4popper
If that is the problem, you will have to disassemble the drive train. Fix whatever is leaking and then clean all the oil off of the clutch and flywheel.
Then reassemble.
My build thread:
post #11 of 14 Old 12-12-2012, 01:37 PM Thread Starter
Rican142
Ok, I am not looking forward to this again x.x
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #12 of 14 Old 07-22-2013, 11:33 PM Thread Starter
Rican142
Hey just catching up on old posts, it turned out to b a blocked catalytic converter, so my excuse wasn't..exhausting lol
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #13 of 14 Old 08-16-2013, 05:58 PM
supertaco
what about an exhaust manifold crack???
and i posted before reading the final post of you saying you fixxed it ... im a tard!
supertaco is offline
post #14 of 14 Old 08-16-2013, 07:40 PM Thread Starter
Rican142
Haha yeah, she put like a kitten...with a bullhorn lol
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
