Exterior Lighting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Exterior Lighting
Jeepforum Coupon for Iron Rock Off RoadRuffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 06-09-2006, 11:54 PM   #1
red hot
Exterior Lighting
Hey,
I have a comanche and pretty much all exterior lights except blinkers do not work. The reason being that no power is getting to the fuse pannel. (except i havent figgured out why the headlights dont work). does anyone have a wiring diagram for the wires that go from the battery to the fuse pannel? my haynes manual shows vaguely everything beyond that. When i cross a wire from the battery direct to the fuse pannel it works (except havent figgured out headlights) so thers something wrong with the hot wire. driving to work at 4am doesnt really work when you dont have lights...
thanks,
~mike
red hot is offline   Reply With Quote
Unread 06-12-2006, 05:48 PM   #2
87manche
check all the fusible lnks that come from the starter relay into the harness. I bet you'll find your problem in one of those. IIRC the light circuit is a green/red one.
87manche is offline   Reply With Quote
Unread 10-26-2006, 01:34 PM   #3
'88 Red Devil
1988 MJ Comanche
Hey Red hot, Did you every get your problem with the lights fixed? I 've got the same problem with my headlights, but seem to have turn signals.
Thanks,
J.W.
'88 Red Devil is offline   Reply With Quote
