Emissions and Vacuum Line - JeepForum.com
post #1 of 3 Old 05-30-2008, 10:06 PM Thread Starter
myriad360
2008 WJ
Ahhh.... I am still punishing myself on my '88 Cherokee. It is running now, but MPG is a dismal 6 MPG. I know there is a cracked header that I need replaced, but I also was inspecting the vacuum line going from the MAP to the Intake Manifold, and right where the elbow meets the bigger plug at the Intake Manifold, it cracked and broke off as I touched it. I tried fixing it, but I am going to have to redo it as I think it is still leaking a little. As the piece kind of fell apart, I ended up replacing a lot of it with soft vacuum line, unlike the OEM hard vacuum line. I am wondering if the hard vs soft type vacuum lines makes a difference, and if I have to remake more of the piece, if I should just get a replacement from the dealership ($), or if I should fab something myself, and if so, if I should take mind of all the internal diameters of the vacuum lines. Or whatever I should know about remaking vacuum lines
Thanks emission experts and physics majors!
myriad360 is offline
post #2 of 3 Old 05-31-2008, 01:04 PM Thread Starter
myriad360
2008 WJ
Anyone have any ideas?
post #3 of 3 Old 06-04-2008, 12:35 AM
carnuck
1984 J-Series Truck
Sorry. Haven't been on here awhile. Hard plastic line is easy to find at most auto parts stores. Run a very good can of injection cleaner (I use BG's 44K)
carnuck is offline
Vacuum Line Help Miami_XJ XJ Cherokee Technical Forum 11 08-22-2010 09:12 PM
Name that vacuum line! 97tjeff XJ Cherokee Technical Forum 2 05-19-2009 07:53 PM
Vacuum line kit? rytomi XJ Cherokee Technical Forum 1 11-10-2008 01:07 PM
Need vacuum line help!!!! Grey4.0L XJ Cherokee Technical Forum 4 02-11-2007 06:49 PM
vacuum line 88XJ_WI XJ Cherokee Technical Forum 9 10-15-2006 08:21 PM
