Door panel madness! - JeepForum.com
post #1 of 6 Old 02-06-2005, 09:28 AM Thread Starter
rustybottoms
Door panel madness!
My door panels are in a pretty sad state, not to mention, they don't match the rest of the interior, and I've been trying to take them off for some time, but I can't figure out how to get the window roller upper off. In the Chiltons it looks like it says to just pull it but I don't want to break anything. Anybody know how to get that thing off?
rustybottoms is offline
post #2 of 6 Old 02-06-2005, 01:32 PM
mdfowler
My 89 Mj has the style that just pop off...i usually grab the base of the crank, right where it is connecting to the door with one hand on each side and slowly pull and wiggle back and forth. If you are in a really cold climate you may want to do this after a drive with the heat on so the plastic is warmer and less fragile.
My e-mail is
... i don't check the one that this forum is attached to, and it will not let me change to a Yahoo e-mail.
mdfowler is offline
post #3 of 6 Old 02-06-2005, 10:23 PM Thread Starter
rustybottoms
thanks doc, I'll give that a shot tonighta!
post #4 of 6 Old 02-07-2005, 01:54 AM Thread Starter
rustybottoms
It worked like a charm, fuglo door panels are no more!
post #5 of 6 Old 02-07-2005, 09:50 AM
mdfowler
Glad to hear! Nobody should have fuglo door pannels!
My e-mail is
mdfowler is offline
post #6 of 6 Old 02-07-2005, 01:10 PM
cj7xjmj
cj7xjmj's Avatar
Some of them had a lil clip that went around the base of the window handle, real PITA to remove, but once removed never put back
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
Getting the door panel off? skenzer XJ Cherokee Technical Forum 8 06-08-2007 03:53 PM
Door panel JBXdudeTJ XJ Cherokee Technical Forum 2 08-10-2006 09:02 PM
Door panel Midtown469 XJ Cherokee Technical Forum 2 02-19-2006 10:11 AM
Door panel jgai11bb XJ Cherokee Technical Forum 3 09-24-2004 11:29 AM
Help with door panel????? 2ksportNY XJ Cherokee Technical Forum 15 04-23-2003 05:43 AM
