Differential stuff - JeepForum.com
post #1 of 6 Old 02-10-2005, 03:03 PM Thread Starter
MJDriver
MJDriver's Avatar
Differential stuff
So I just bought the Comanche a few months ago, and for the first time cracked open the diffs, today. The front diff is fine, fluid's a good color and decent level. The rear is a charcoal grey color and nasty. Its a Dana 44.
- Does this mean it got water in it or the fluid heated up too much?
- I found a tag that says "Use Limited Slip Diff Oil Only"...Does this mean I have the Trac-lok diff?
- What is this oil and why doesn't the Chilton Manual mention it?
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #2 of 6 Old 02-10-2005, 03:48 PM
cj7xjmj
cj7xjmj's Avatar
A slight grey tinge is normal. The limited slip additive is available at the local auto parts stores, should only cost a few bucks, or you could run synthetic which all ready has this additive. I am not sure wether it means you have a trac-lock diff, but it could mean that.
While you are replacing the fluid, it is a good time to replace your vent tube. They tend to dry rot within a yr or so, and you dont want to be like me and destroy an axle cause of 3 dollars worth of rubber.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #3 of 6 Old 02-10-2005, 05:30 PM Thread Starter
MJDriver
MJDriver's Avatar
Vent tube? I'm sure it must be shot because the only tubes I see are brake lines.
Where is it located, what diameter and how long should the tubing be? Is it held on by itself or a ring clamp?
By the way, thanks for the heads up. Also, the fluid was charcoal grey/black. Ugh.
MJDriver is offline
post #4 of 6 Old 02-10-2005, 06:21 PM
cj7xjmj
cj7xjmj's Avatar
There should be a nipple or something similar to it close to where the rear flex line connects to the axle. It should run a pretyy narrow diameter tube up from the axle to the frame if not higher. It is used to let the oil have room to breathe.
Patrick
cj7xjmj is offline
post #5 of 6 Old 02-10-2005, 10:07 PM Thread Starter
MJDriver
MJDriver's Avatar
Thanks. The whole diff is coated in gunk, so I'll clean it and find the spot you're talkng about.
Thanks again.
MJDriver is offline
post #6 of 6 Old 02-12-2005, 04:39 PM Thread Starter
MJDriver
MJDriver's Avatar
I found the tube. Aside from the axles being coated in gunk the tube was in good shape, and very pliable. I will just have to keep an eye on the fluid and see how it does, I guess.
Thanks for the help.
MJDriver is offline
zj to xj stuff 96fleXJ XJ Cherokee Technical Forum 5 01-13-2009 11:30 AM
stuff in oil...like metal kind of stuff dirt machine XJ Cherokee Technical Forum 15 03-12-2007 08:38 PM
Need XJ Stuff? 91xjfireman XJ Cherokee Technical Forum 1 06-22-2006 08:26 PM
Seriously looking to stuff a 350 in. big4.0block XJ Cherokee Technical Forum 12 11-27-2005 01:47 PM
lift stuff and noob stuff crazyjeeps XJ Cherokee Technical Forum 5 03-25-2003 05:26 AM
