Dash light and other electrical problems. 1990 - JeepForum.com
post #1 of 5 Old 11-07-2012, 06:00 AM Thread Starter
bradleytjohnson
what sort of part would I be looking for if almost none of my interior electrical things work.
- radio will play sometimes but shortly will stop
- dash light doesnt turn on
- I think there's a clock next to the radio, it sometimes turns green but it never is on when I have my lights on.
Also, is anyone elses headlights really dim?
bradleytjohnson is offline
post #2 of 5 Old 11-07-2012, 09:03 AM
97_4popper
1990 MJ Comanche
Couple of things for you...
1st. I'm originally from New Albany. My best friends live in Georgetown.
2nd. Sounds like you may have multiple problems. I would check all your grounds. Check the output of your alternator.
Your dashlights could be the headlight switch or a fuse. Get a multimeter and start diagnosing these things.
Let us know how it goes.
3rd. Go over to comancheclub.com... Everything you need to know about these trucks is over there.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
http://img.photobucket.com/albums/v1...IMG_0101-2.jpg
Check out comancheclub.com...
My build thread: http://comancheclub.com/forums/viewt...hp?f=7&t=27756
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 5 Old 11-07-2012, 05:52 PM
ftpiercecracker
1990 MJ Comanche
broken fuses, burnt fuses, bad fuses, bad fuse clips. and go to comancheclub.com
ftpiercecracker is offline
post #4 of 5 Old 11-08-2012, 11:20 AM Thread Starter
bradleytjohnson
Thanks you all! Holy **** small world lol.
post #5 of 5 Old 11-11-2012, 05:25 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Renix Ground Refreshing
The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components.
The components grounding at the dipstick tube stud are:
Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff.
The factory was aware of the issues with this ground point and addressed it by suggesting the following:
Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint.
Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely.
While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely.
Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end.
First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely.
Remove the other end of the cable from the rear of the head using a 3’4” socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely.
A suggestion regarding the braided cable:
I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18” long with a 3/8” lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116.
A further improvement to the grounding system can be made using a #4 cable, about 10” long with 3/8” terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115.
If you want to upgrade your grounds and battery cables in general, contact Jon at www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price.
Revised 11-28-2011
cruiser54 is offline
