Dana 60 for MJ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > Dana 60 for MJ??
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 01-23-2014, 05:05 PM   #1
Scottracer1
Dana 60 for MJ??
Hello,
Someone is getting rid of a Dana 60 Rear out of an J10 pickup. I am sure some work will need to be done but is there any major restrictions for putting it in an MJ. 87 4x4 4.0L
Thanks
Scottracer1 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2014, 02:18 PM   #2
Timeless
1987 MJ Comanche
The pumpkin might be offset depending on year meaning you may have to trim the longer tube. Bolt pattern is probable 5x5.5. If its a D60-2, it should have 35 spline shafts, if not, don't even bother with it. The pinion will me much longer than your factory axle (assuming you're running a stock axle) so plan on shortening your drive shaft. The only major restriction is what the actual axle is and your time and skill.
Timeless is offline   Reply With Quote Quick reply to this message
