Comanche won't run help! - JeepForum.com
post #1 of 6 Old 12-31-2012, 07:37 PM Thread Starter
M1doesmytalking
Jeep comanche has no fuel or spark the truck shut off when I switched the heater from defrost to bi level the truck just shut off and would not start again. Things to add the headlights won't turn on the turn signals won't work not brake lights are not working. The dash lights come on but the engine just cranks but won't fire all fuses are good an i tried another computer. No change. It's a 1988 4x4 sportruck 4.0l 5 speed manual
M1doesmytalking is offline
post #2 of 6 Old 01-01-2013, 05:58 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sounds like bad battery cable connections to me. Or, a failed battery. Back to basics.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 6 Old 01-01-2013, 06:35 PM
93sasrunner
motor turns over good battery is not the problem dash gets power but will not spark and fuel pump will not pressure the rail., fried dash harness? any suggestions will help its his DD and he has to drive my 4runner to work till its up and running. HELP main fuses hiding somewhere that we cant fid or something weird?
93sasrunner is offline
post #4 of 6 Old 01-01-2013, 08:21 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Are you like major hijacking or what?
post #5 of 6 Old 01-08-2013, 02:44 AM Thread Starter
M1doesmytalking
bump still nothing im thinking im just gonna have to pull the dash harness
post #6 of 6 Old 01-08-2013, 08:43 PM
Comanchekid1k
1990 MJ Comanche
maybe its multiple problems that happened at once. One problem is it sounds like the fuel pump died, or the fuel filter is clogged up?
also maybe the ignition coil needs to be replaced?
#livintheJEEPlife, JustEmptyEveryPocket
Comanchekid1k is offline
