Comanche Starter??? - JeepForum.com
post #1 of 4 Old 12-30-2013, 04:08 PM Thread Starter
Ryan1018
1988 MJ Comanche
Comanche Starter???
I have a 88' Comanche 2WD with an AMC inline 6. I've had the truck for about 2 years and have experienced a problem with it starting. Everything will power on but when you go to start the truck nothing happens. No clicking or anything. I've always just let it sit and then it would eventually start back. Now, it is apparent that the truck will not start at all after multiple attempts. I've tested the battery and it is good. I read the service manual and it most likely points to the starter going bad but I'm not a mechanic so I want to be sure before I buy one. When the truck would start in the past, it seemed like the starter was fine. It didn't seem weak or anything like that. Any suggestions?
Ryan1018 is offline
post #2 of 4 Old 12-30-2013, 05:05 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Ryan, click on the link in my signature and go to post # 1.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 4 Old 12-30-2013, 08:08 PM Thread Starter
Ryan1018
1988 MJ Comanche
Thanks Cruiser. It will be this weekend before I can check anything out but this has been helpful. I should have thought of that. A loose ground would explain the intermittent starting problems...
Ryan1018 is offline
post #4 of 4 Old 12-31-2013, 07:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Keep us in the loop.
