Comanche sounds like a diesel - JeepForum.com
post #1 of 7 Old 05-13-2008, 06:07 PM Thread Starter
talthaus
1991 MJ Comanche
Somebody please give me any ideal as to why under heavy acceleration my 4.0 inline 6, 1991 comanche sounds like a diesel truck when I punch it. It has 200K+ miles, just replaced the water pump and the belt it good and tight. I'm at a loss to figure this one out, any help is appreciated. Thanks
talthaus is offline
post #2 of 7 Old 05-13-2008, 07:25 PM
maddzz
1989 MJ Comanche
Not sure what you mean by sounds like a diesel. Is it just loud. Head over to comancheclub.com Better chance of some help
maddzz is offline
post #3 of 7 Old 05-14-2008, 08:12 AM
rworks
Are we talking "clatter"? Could be a sticky lifter.
rworks is offline
post #4 of 7 Old 05-14-2008, 10:29 AM
SuperWade2
More Money than Brains
SuperWade2's Avatar
My lifters are all really noisy too... sounds like a Mini-Diesel too...
Not much I've done has had any effect... will be rebuilding at some point in the future...
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #5 of 7 Old 05-14-2008, 12:17 PM
Pete M
1988 MJ Comanche
Could be pinging maybe? H.O. engines don't have a knock sensor. Try throwing an octane booster in the tank.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #6 of 7 Old 05-15-2008, 06:45 AM Thread Starter
talthaus
1991 MJ Comanche
Thanks to all that replied
Thanks guys, I appreciate your replies, I finally figured it out. I was a little low on oil and the oil light flickered just before shifting at red line, added oil, noise went bye bye. The noise sounded like a diesel sitting at idol the kind of have that metalic rattle I don't know how else to describe it. The noise wouldn't be all the way through exceleration just at the end of a shift point under wide open throttle. During light exceleration it would not do it at all.
Take care!!
talthaus is offline
post #7 of 7 Old 05-15-2008, 09:44 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Sounds like you could use a gauge cluster swap so you can monitor you oil with a PSI gauge...
Either way, congrats on getting it figured out.
88XJSport is offline
XJ Sounds like a diesel---no good 89bluexj XJ Cherokee Technical Forum 6 03-19-2009 06:31 PM
4.0 sounds like a diesel jfn234 XJ Cherokee Technical Forum 6 08-12-2008 01:02 PM
sounds like a diesel hafmansredxj XJ Cherokee Technical Forum 2 05-23-2006 09:43 AM
XJ sounds like a diesel at idle sometimes fourlow XJ Cherokee Technical Forum 7 06-13-2004 01:53 PM
XJ sounds like a diesel??? NevadaXJ XJ Cherokee Technical Forum 22 01-24-2004 08:28 AM
