Comanche Roll Bar - JeepForum.com
post #1 of 16 Old 02-21-2005, 02:44 PM Thread Starter
gonoles
1982 DJ
Comanche Roll Bar
Anyone know where I can get a roll bar for my 87 Comanche Sport? I have seen Comanches that have them, but havent been able to find them.
Thanks,
Greyson
gonoles is offline
post #2 of 16 Old 02-24-2005, 04:40 AM
steve55
I have a roll bar off my 88 comanche. Still has factory lights. No idea what its worth. Steve
steve55 is offline
post #3 of 16 Old 02-24-2005, 08:27 PM Thread Starter
gonoles
1982 DJ
would you be willing to sell it? if so, what would you like for it, and how much do you think it would cost to ship to North Carolina, zip code 27592
gonoles is offline
post #4 of 16 Old 02-27-2005, 09:04 PM
silverxj2001
silverxj2001's Avatar
just letting you know thats not gonna help you much in a rollover
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
silverxj2001 is offline
post #5 of 16 Old 12-26-2007, 10:12 PM
Mudhound0530
1988 MJ Comanche
I am also in the business of finding a rollbar. This is mostly for my dad to stop pestering me about it. I have kind of a reputation for being a bit on the wild side and pushing the envolope...so i have two questions,
Why is it not that helpful to have a rollbar?
Will this fit...http://rustysoffroad.com/mm5/merchan...gory_Code=ROLL
88 MJ 94 XJ
09 JKRU SOLD
14 Chevy Silverado Quad Cab 4x4
Mudhound0530 is offline
post #6 of 16 Old 12-27-2007, 06:59 PM
COMANCHE4X4
1989 MJ Comanche
I donít think the Rusty bar will fit a Comanche as they are different floor pans than the XJ ..But you could call or email them to find out.
As for the comment on the factory bar not helping, it is designed for show, to look good and was not made of strong thick walled tubing or mounted well enough to provide "much" protection it will offer some in a light roll but not in a violent roll over situation
COMANCHE4X4 is offline
post #7 of 16 Old 12-28-2007, 09:17 AM
camjeep3
1988 MJ Comanche
try also looking for one from other trucks of similar size, i have one from a mid 80s ranger which fits perfect. i also might be selling it
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline
post #8 of 16 Old 12-28-2007, 11:35 AM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
First gen Chevy S-10 rollbars also fit with little to no issues.
LEAD_NOT_FOLLOW is offline
post #9 of 16 Old 12-28-2007, 11:14 PM
A-man930
What would you guys say is the going rate for a custom roll bar is?
-Alan
1990 MJ Pioneer, 4.0/AX-15 4" on 32"
240,xxx and counting!
A-man930 is offline
post #10 of 16 Old 12-31-2007, 03:52 AM
mca1977jpsnet
Most any Roll bar from a small truck should work from simular size truck. Check with your local truck shop. Ford Ranger, Chevy S-10, Toyota, nissan, or mazda compact turck of simular years should all work. Good luck finding what your looking for
mca1977jpsnet is offline
post #11 of 16 Old 01-03-2008, 06:32 AM
chuckyj95
I had one out of a old dakoda fit great.
Chuck Longwell
Mohawk NY
Looking for my next jeep
2008 Triumph Speedmaster
chuckyj95 is offline
post #12 of 16 Old 03-23-2008, 12:00 PM
SB6114
1987 MJ Comanche
Do you guys think there is a difference between the roll bar in the comanche longbeds and the shortbeds? I have an '87 shortbed that I'm fixin up and found one from a longbed in pretty good shape but I don't have a good enough picture to tell if it would switch over.
SB6114 is offline
post #13 of 16 Old 03-23-2008, 04:23 PM
Pete M
1988 MJ Comanche
Between the factory longbed bar and the factory shortbed bar? Yes, absolutely they are different. And they are not interchangeable. But if it's an aftermarket bar, then it should work fine in your truck. The factory bars have their rear downbars bolted to the sloping side of the wheel well. Aftermarket ones will either bolt to the bedfloor or to the top of the wheel well and those bars should work for both long or shortbeds. If it is a factory bar in good shape, I'd grab it if I were you. Plenty of guys over at the comancheclub.com/forums that would buy it from you.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #14 of 16 Old 05-15-2008, 12:58 PM
SB6114
1987 MJ Comanche
Ok, so I went ahead and grabbed the FACTORY longbed roll bar, but I can't use it. If I can't find a shortbed bar I'm just going to give this one the chop and resize it for a shortbed, BUT if anyone has a shortbed bar or could get one and would be interested in trading please let me know!!!!
'01 XJ Sport, 4.0 with NV3550, 4x4, Up Country. Added: electric fan conversion, overhead console, and TUPY head (@%&$^#!).
'87 MJ shortbed, no rust! - Restoring using best parts from '87, '89, '96, '01 MJ's/XJ's. Black with chrome, Up Country, D44, NV3550, fog lights, roll bar.
SB6114 is offline
post #15 of 16 Old 05-15-2008, 01:01 PM
SB6114
1987 MJ Comanche
Oh, if anyone wants to see a picture I can send some to ya.
SB6114 is offline
No more oil under Comanche now PitBull4X4 MJ Comanche Technical Forum 0 07-27-2009 11:26 PM
Comanche Rear Roll pan info? Shuggystone XJ/MJ Cherokee Non-Technical Forum 0 04-28-2009 07:33 PM
86 comanche 2.5 4 cyl. BASIL PORTER MJ Comanche Technical Forum 1 12-30-2007 10:04 PM
Comanche ???? 86comanche XJ Cherokee Technical Forum 8 01-29-2005 08:12 AM
Comanche roll call Alec XJ Cherokee Technical Forum 7 01-06-2005 08:46 PM
