Comanche with an oil leak. Do I need a new block? - JeepForum.com
post #1 of 7 Old 12-04-2011, 08:04 AM Thread Starter
nickhuts
1990 MJ Comanche
So I bought this comanche with a lil oil leak about a month ago.
After getting it up on the car lift I determine its a rear main seal.
No big deal. I swap it out and then relise that there is a chunk of the block missing. Its a little triangle that had been chipped off (probably the previous owner attempting to get the seal out with a hammer and screw driver...but missed!) It is a thin piece of block between the rear main seal and the end of the crank...ugh! Do I need a new block? I "glued" the piece back in there with RTV sealent like it was before and now Its leaking about a 7 in oil circle on the floor in about 3-5 minutes (same if not worse then before) .
Maybe take it back apart and use some JB weld. Its easy to get to with out the front drive train in.
any ideas?
nickhuts is offline
post #2 of 7 Old 12-04-2011, 11:17 AM
automan2164
1986 MJ Comanche
Any pics of it?
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #3 of 7 Old 12-04-2011, 11:49 AM Thread Starter
nickhuts
1990 MJ Comanche
Ok this is not mine but I found this on google. it should give ya an idea.
nickhuts is offline
post #4 of 7 Old 12-04-2011, 01:55 PM Thread Starter
nickhuts
1990 MJ Comanche
just got some marine JB weld and stuck it back in there. I will put the oil pan back on tomorrow night and fire it up tuesday....fingers crossed....
nickhuts is offline
post #5 of 7 Old 12-07-2011, 01:58 PM Thread Starter
nickhuts
1990 MJ Comanche
Let the motor warm up a lil bit...no leak
Held the rpms at 2000...seems to be golden
JB weld saved my block. Time will tell
nickhuts is offline
post #6 of 7 Old 11-26-2012, 05:25 PM Thread Starter
nickhuts
1990 MJ Comanche
ok update...the JB weld is STILL holding..about one year later...freaking awesome stuff!!
nickhuts is offline
post #7 of 7 Old 11-26-2012, 10:16 PM
ftpiercecracker
1990 MJ Comanche
good fur you!
ftpiercecracker is offline
2000 4.0 block in 89 comanche? cpradio XJ Cherokee Technical Forum 5 02-28-2011 09:38 PM
86 comanche front axle leak fernjohn MJ Comanche Technical Forum 2 11-16-2010 07:56 PM
another comanche is hitting the FS: block jebnmikki MJ Comanche Technical Forum 0 08-27-2010 09:04 PM
84 Comanche Clutch Slave cyl leak guruofguns MJ Comanche Technical Forum 5 11-12-2009 11:20 AM
new fuse block? am i a block head? 2nd alt? futurefd XJ Cherokee Technical Forum 3 02-12-2007 11:37 AM
