comanche mj brake preportional valve
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#1 | |
i have a 1987 jeep comanche 4x4 with a 4.0l and aw4 transmission. i lifted the truck 5 inches in the front and 3 in the rear.
when i first lifted it i moved the preportioning valve down 3" so it would work with the lift. this made the wheels lock up too quick. then i put it back to were it was when i started. the brakes work fine but they seem a little weak. does anybody know how to adjust this valve http://www.cardomain.com/ride/2992336
#2 |
I would find the sweet spot with the arm and duct tape it there. there are no adjustments procedures to the valve itself and no replacements available. if it's gone bad, the next step is to trash it and go with an aftermarket adjustable prop valve.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc. Also an 86 MJ Metric ton and 2 '90 MJs Projects/wheelin' pics: picturetrail.com/petermontie My email: petermontie@hotmail.com ComancheClub.com/forums |
#3 |
how can i bypass this valve. i refuse to use duct tape on this i just want to know how far i need to drop it and im gonna weld the bracket for it
#4 |
remove the valve and replace it with a 'T' fitting. But then you won't have any proportioning. the front valve that looks like a prop valve is really just a splitter.
-So you could remove the rear valve and splice in an aftermarket valve -Or you could remove the rear valve and swap in an XJ front valve up front (and with it, remove one of the rear lines in the MJ since the XJ only has one line running to the rear axle)
#5 |
I'm doing what Pete M suggests. Bought me a roll of coated line and a 88 xj porp valve. replumbing the h/v porp right out
#6 |
I did basically the same thing when I first got my MJ. There were two blown lines and the load sensing circuit was rusted beyond belief. I ended up taking the prop valve from my Cherokee that I had laying about and just put that in. You don't need to run new lines unless you want to, it fits right in (just ignore or remove the front linen as that's for the load sensing circuit).
You will also have to bypass the T fitting right above the rear axle. If you don't, then this could cause a massive leak in the rear.
1986 Jeep Comanche 126000+ miles Long Bed, Chevy 350 (5.7L V8), AX15, NP231 Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come... 1992 Jeep Comanche 174000+ miles Short Bed, 4.0L I6 HO, AX15, NP231 In the process of doing a frame up restoration. ...RIP... 1990 Jeep Cherokee XJ 207774 miles 4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion |
#7 |
both my lines were so bad that they were just about to disinagrate. looks like running the right front line might be worse than the rear, they way it is tucked up against the fitewall.
#8 |
You don't need to exactly copy the factory lines. Feel free to run them where ever you like as long as it won't get hurt or get in your way of future repairs.
#9 |
i removed mine but i didnt add a xj valve and i think they work great.
#10 |
did the prop valve in a cherokee change at all in any years or will any xj valve work. cause some companys only sell the 84- 86 prop valve
#11 |
I'm running off memory here so I might be wrong but...I believe the did change it from '86-'87 with different valving. When I ripped into my '92 MJ, I had the regular sized Cherokee brakes. But when I ripped into my '86 Comanche, I had the thinner brake shoes. Besides this '86, I haven't seen these thinner shoes on any other XJ or MJ that I've had (I've owned a '90 XJ, '92 XJ, and '92 MJ with all the same rear brake shoes).
#12 |
One thing I did that I now regret is I put the rear wheel cylinders for an AMC Eagle in (because they are a bigger bore for more rear braking) THEN I discovered my rear brakes had no pressure (after driving for almost a year) because the rear valve was shot AND the brake line was rotted through! (only rust on the whole truck!) I bought a line adapter (7543 IIRC?) and screwed the original front to back line direct to the brake hose and capped the other line at the front.
Now I can lock them up TOO easily, even with 33" tires if I don't have weight in the back. Adjustable prop valve AFTER I finish the double booster swap!
"Usually found in a Jeep near Reiter, WA" |
#13 |
If you're going full custom, do away with the proportioning valve, load sensor, etc. Run your front line from the MC down to the brakes with a simple "T". Put an adjustable valve on the rear line, and adjust it so the rears don't lock up. If you're putting an adjustable in anyway, there's no need to keep the factory valve. Only down side is, the brake light on the dash won't work as a warning system in the case of a partial system failure.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice." |
#14 |
In the FSM there is a procedure for setting the angle of the lever on the rear valve for proper operation. It would seem that if the angle were set correctly, your lift wouldn't be an issue as long as the rod was lengthened to compensate for the lift.
#15 |
I think the problem with lift isn't the valve adjustment, but the increase in rear suspension travel. If you get much more travel then stock, regardless of how the valve is set, it's going to bottom out one way or the other, and probably tear itself apart.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
