Comanche leveling kit - JeepForum.com
post #1 of 4 Old 02-16-2013, 05:51 PM Thread Starter
Ryan1018
1988 MJ Comanche
I have a 1988 2x4 comanche. The front end sits about 2-3 inches lower than the rear. What would be the most cost effective way to raise the front to match the rear?
Ryan1018 is offline
post #2 of 4 Old 02-19-2013, 02:49 PM
Pete M
1988 MJ Comanche
2" poly lift pucks.
be prepared that lifting the front end can alter the alignment. but with only 2" it should be ok.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 4 Old 02-19-2013, 05:33 PM
JeepComanche89
1989 MJ Comanche
Honestly i would just buy new suspension parts. If your front is sagging more than it should, then your coils are worn.
JeepComanche89 is offline
post #4 of 4 Old 02-22-2013, 10:49 PM
carnuck
1984 J-Series Truck
If it is 4 cyl, score XJ 4x4 4.0L coils and you'll be good to go!
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
