Quantcast comanche 2wd 4x4 conversion - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > comanche 2wd 4x4 conversion
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 07-14-2009, 06:38 PM   #1
workinman
hello to all this is my first jeep but my 3rd truck and i just wanted to know how difficult it would be to convert my 88 comanche from its stock 2wd to and strong working 4x4 i am very mechanical i've done motor swaps lifed and lowered trucks but what i had in mind was a donor comanche or cherokee because i understand they're pretty much the same along the lines of an s10 and a blazer. the only reason i believe this would be easier than usual is because of the straight front axle on the MJ. anything would be much appreciated thank you and be safe
workinman is offline   Reply With Quote
Old 07-15-2009, 03:31 PM   #2
1984XJ
1990 XJ Cherokee
youll need a new axle, t-case, front driveshaft, all the linkage, shifter nob, etc.
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
_(o)_)____(o)_)--o)_)
Daily Driver Jeep #16
Utah Jeep'n
1984XJ is offline   Reply With Quote
Old 07-15-2009, 06:58 PM   #3
workinman
well yeah i've been going over this in my head. so it would be possible relative eay (Saying everything cooperates) to just swap parts from the 4wd cherokee to my comache?
Old 07-15-2009, 07:01 PM   #4
1984XJ
1990 XJ Cherokee
.......Its not an easy job, but if everything go's well, it should be pretty straight forward
.,_______.o_o.
//_|__l__,\___\,___
Utah Jeep'n
Old 07-16-2009, 04:33 PM   #5
Pete M
1988 MJ Comanche
Everything bolts in. The tricky thing is matching the new stuff to your engine and then the gearing in the axles (making sure they don't suck). Add to that list above a 4wd trans and a shorter rear driveshaft (you can get your current one cut down).
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email: petermontie@hotmail.com
ComancheClub.com/forums
Pete M is offline   Reply With Quote
Old 07-21-2009, 04:04 PM   #6
workinman
ok thats what i was thinking. at first i was hoping to just swap bodies because i like the mj body style better. but being that they're uni body's i cant. but i'll try and give it a shot after i pick up my donor jeep, thank you for the up front answers
Old 08-04-2009, 08:56 PM   #7
LalanP111
mtn dew junkie
LalanP111's Avatar
http://www.jeepforum.com/forum/f53/mj-question-about-converting-2wd-4wd-667293/
1998 TJ, 4.0L, RC 2.5", 31x10.5-15 Duratracs (sold)
1988 MJ, 4.0L ..soon for be on 33's and 6.5" LA/SOA (project)
2004 TJ, 4.0L, Columbia Edition, 2"BB, 31x10.5-15 (DD, future project)
Originally Posted by Knuckelhead View Post
It takes care of me and in return, I take care of it. Takes me away from everything I don't want to be around, and back again when needed...
LalanP111 is offline   Reply With Quote
Old 08-06-2009, 08:12 PM   #8
carnuck
1984 J-Series Truck
Find out what your current rear axle ratio is and find a front one to match (unless you plan to lift at the same time)
carnuck is offline   Reply With Quote
Glock Forum
