Cold Air intake question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Cold Air intake question
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 03-10-2012, 10:23 AM   #1
JeepComanche89
1989 MJ Comanche
Im looking to get a aftermarket air intake for a 89 comanche, with a 4.0. I have found nothing that claims it will fit anything later than 91. I believe that this is due to the renix engine? What I am asking is would just any intake work, or schould I buy a univeral rubber tube and filter.
And finnaly would this be a good idea or no?
http://www.summitracing.com/parts/SPE-9945/?rtype=10
If anyone could help I would appreciate it. Thanks in advance
JeepComanche89 is offline   Reply With Quote
Unread 03-10-2012, 04:04 PM   #2
McBeast
1986 MJ Comanche
I just got the spectre intake pipe from autozone for 40 bucks along with the large airfilter. The employee autozone said it should work, but I haven't installed it yet.
McBeast is offline   Reply With Quote
Unread 03-10-2012, 04:24 PM   #3
JeepComanche89
1989 MJ Comanche
Ok thanks ill check that out. Let me know how it works out for you. Also if anyone else knows something please chime in.
Unread 03-10-2012, 06:22 PM   #4
ftpiercecracker
1990 MJ Comanche
What are you supposed to do with the "umteen" vacuum lines going into the air box, there are two small ones that go into the back, a larger near the top, and a really big "cloth" hose that attaches to the very front.
what happens to these?
ftpiercecracker is offline   Reply With Quote
Unread 03-10-2012, 06:35 PM   #5
cruiser54
1990 MJ Comanche
I don't think the CAI is worth it. Actually it's a hot air intake as it ingests air from the engine compartment instead of in front of the radiator support like the stock intake does. And then, there's the issues of the CCV system working properly as you expressed your concerns as to what you're gonna do with all the vacuum lines.
cruiser54 is offline   Reply With Quote
Unread 03-10-2012, 07:02 PM   #6
ftpiercecracker
1990 MJ Comanche
Unread 03-10-2012, 08:18 PM   #7
cruiser54
1990 MJ Comanche
I just remove the factory airbox and use a 2.5" holesaw to put a coupla holes in the driver's side of it.
Unread 03-10-2012, 08:26 PM   #8
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I'm a fan of the guys who run the intake hose into the cowl area at the base of the windshield.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - DD/Light Trail Rig - The War Wagon
75 CJ5 with a badly chopped CJ7 Tub - Pandora
dagr8tim is offline   Reply With Quote
Unread 03-11-2012, 06:01 AM   #9
cruiser54
1990 MJ Comanche
That seems to make more sense and really serves a purpose if you are in the water.
Unread 03-11-2012, 07:49 AM   #10
JeepComanche89
1989 MJ Comanche
Thats what i was thinking. Does the one in my link seem worh it?
Unread 03-11-2012, 08:00 AM   #11
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
http://www.jeepforum.com/forum/f11/t...ntake-1338437/
http://www.jeepforum.com/forum/f177/...ntake-1106513/
Amazing what alittle searching will give you. There are others that are a variation on a theme.
Here are afew from a google image search:
Lastly, here's a write up:
http://www.ericsxj.com/intake/intake.htm
Unread 03-11-2012, 08:25 AM   #12
JeepComanche89
1989 MJ Comanche
Thanks for the info. But one more question has anyone ever run a HO intake on a renix? I am aware that the Renix has extra tubes, but have the engine out now so I cant tell if it would make a differnce if removed.
Unread 05-01-2012, 11:01 AM   #13
BigRedWilkey
Rustys offroad Airtube for the xj's will work
BigRedWilkey is offline   Reply With Quote
Unread 05-06-2012, 06:51 PM   #14
JeepComanche89
1989 MJ Comanche
Yes but what do you do with the smog fittings on the header?
Unread 05-09-2012, 08:28 AM   #15
BigRedWilkey
They connect to the Airtube. The hose on the very bottom can just be disconnected.
