coil and ignition - JeepForum.com
post #1 of 3 Old 04-16-2008, 08:37 AM Thread Starter
romeo_zooloo
1989 MJ Comanche
coil and ignition
I have an 89 MJ with a 4.0L and I have been having some problems keeping it running at low rpms. I have started replacing the vacuum lines just because of their age and condition. My air filter was saturated with oil and I cleaned the housing and replaced the air filter. I cleaned the throttle body area with throttle body cleaner. It is running a little better.
Last night I was looking under the hood with the engine running and saw a few stray sparks around my coil and the no. 1, 2, and maybe 5 plugs. Is this normal to lose some fire? Should the coil, wires and plugs be replaced?
Thanks
Roger
romeo_zooloo is offline
post #2 of 3 Old 04-16-2008, 12:42 PM
88xjchief
1989 MJ Comanche
When was the last time you did a tune up? I would replace plugs, wires, cap, and rotor and see if that helps. You should not be loosing any spark.
Red Jeep club #419
88xjchief is offline
post #3 of 3 Old 04-16-2008, 12:59 PM
SoloCamo
1988 MJ Comanche
Yea, I would definitely replace the cap, wires, plugs and rotor just as pre-cautionary, especially considering the situation. As stated, you should not be losing any spark, let alone being able to see it that easily.
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline
coil and ignition romeo_zooloo MJ Comanche Technical Forum 0 04-16-2008 08:28 AM
ignition coil Fulk1204 XJ Cherokee Technical Forum 6 04-12-2007 02:45 PM
Ignition Coil jblaine XJ Cherokee Technical Forum 2 08-19-2006 12:57 PM
ignition coil upgrade Jeepin1413 XJ Cherokee Technical Forum 13 09-17-2004 11:53 AM
Ignition coil mbood82 XJ Cherokee Technical Forum 6 12-01-2003 10:54 AM
