Clutch Slave Cylnider Question - JeepForum.com
post #1 of 3 Old 06-16-2008, 12:36 PM Thread Starter
nate81
I have an 88 Comanche 2wheel 6cyl. I have to get the clutch slave cylinder replaced and I was gonna do the work myself, but I am not sure if I have to drop the transimission to replace it. If I have to drop the tranny then I am gonna have someone else do the work, but if not, then I will do the work myself. Can someone please let me know if the tranny has to be dropped in order to replace the clutch slave cylinder. Thank you.
nate81 is offline
post #2 of 3 Old 06-16-2008, 06:26 PM
Pete M
1988 MJ Comanche
Yes, the tranny much be dropped as the 88's factory slave is located inside the bellhousing (called an "internal slave").
What leads you to think it's the slave? Is it leaking?
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 3 Old 06-22-2008, 05:14 PM Thread Starter
nate81
thanks for the reply,it turns out that a friend suggested jus bleeding the system and sure enough it worked thank you again .
nate81 is offline
Clutch and Slave Help Dogberri XJ Cherokee Technical Forum 2 11-09-2009 11:21 AM
Transmission and clutch slave cylinder question Comanchejay XJ Cherokee Technical Forum 0 01-07-2009 12:59 PM
clutch/slave cylinder help. Please.. gharmon XJ Cherokee Technical Forum 4 02-08-2007 01:11 PM
Clutch Slave or master TPG013 XJ Cherokee Technical Forum 1 08-23-2002 08:58 AM
Clutch Slave Cylinder jcrowley XJ Cherokee Technical Forum 4 02-05-2002 10:17 AM
