Clean out ccv system - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > Clean out ccv system
Savvy Aluminum Gas Tank SkidFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge Pins
Unread 02-18-2014, 06:29 PM   #1
Joswhi6561
1987 MJ Comanche
What is the best way to clean out my ccv system anything I have to buy from auto zone?
Joswhi6561 is offline   Reply With Quote
Unread 02-24-2014, 01:31 PM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Carb cleaner.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
Refresh*Connections*Before*Replacing*Components
cruiser54 is offline   Reply With Quote
Unread 03-05-2014, 08:32 PM   #3
carnuck
1984 J-Series Truck
Actually, throttlebody cleaner because some of those carb cleaners have chemicals that can hurt the O2 sensor and eat up the IAC.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 03-05-2014, 08:33 PM   #4
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Really? How does a cleaner eat up a METAL IAC? And, there are oxygen sensor safe carb cleaners. Most all of them are anymore.
Unread 03-11-2014, 08:29 PM   #5
carnuck
1984 J-Series Truck
The IAC has electrical components that the cleaner gets into. It's not all metal or it wouldn't work now would it? The threads inside get gummed up and the throttlebody cleaner has a minute amount of lube in it most carb cleaners don't.
FOR SALE STUFF
Unread 03-11-2014, 11:07 PM   #6
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Another post of useless bull**** from caryuck.
Unread 03-12-2014, 05:45 PM   #7
carnuck
1984 J-Series Truck
Don't get your panties in a bunch Alice. None of us are infallible. Get used to it.
FOR SALE STUFF
Unread 03-12-2014, 06:33 PM   #8
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There's no lubricant in throttle body cleaner...
It's oxygen sensor safe for sure where carb cleaners can go either way.
And, it won't eat the coatings off on some throttle bodies that have them, where carb cleaner would.
O2 sensors don't respond well to "lube"..
