Check Engine light codes - JeepForum.com
post #1 of 5 Old 02-16-2005, 11:05 AM Thread Starter
Country Jeep
Comanche Kemosabe
Country Jeep's Avatar
Do Comanche's and Cherokee's not have the same feature that a ZJ has? Where you can turn the key 3 times (or 5, I forget) and have the computer blink the Check Engine light a certain amount of times to blink out a code? The ZJ's have that feature where you check a book, read the number of times the Check Engine light blinks, and see if you have any probs with the motor. Do the Cherokee's and Comanche's not have that feature or what?
Main rig under screen-name...
, 4.0L HO I6, AW4. Daily driver.
'98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project.
Gone, but not forgotten:
, '94 ZJ Limited, '85 CJ7,
Blue Jeep Club Member #113
Country Jeep is offline
post #2 of 5 Old 02-16-2005, 01:11 PM
moonlight_dan
moonlight_dan's Avatar
1999 MJ Comanche
My 93 Cherokee has that feature. I havn't tried the MJ yet.
99 Cheromanche - Frame and bed are the only stock parts
90 Cherokee DD
moonlight_dan is offline
post #3 of 5 Old 02-16-2005, 02:11 PM
cj7xjmj
cj7xjmj's Avatar
Unfortunately the older Renix computers do not have that feature. They do have a comp hook up under the hood, but you need a special scanner to read it. Also it only tells you if something is out of range, not if it is bad.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #4 of 5 Old 02-16-2005, 02:33 PM
Comanche5L
codes
yep, has to be '91 or newer, and the MJ's work the same as the XJ's.
'88 Comanche, '01 front clip, Mustang 5L, T-5 & Tonns of unnecessary noise
'91 Comanche, '01 front clip, I6 H.O, RE 3.5" Superflex
'91 CJ'd Sahara 4L
Comanche5L is offline
post #5 of 5 Old 02-16-2005, 02:36 PM Thread Starter
Country Jeep
Comanche Kemosabe
OK, thanks all
Check Engine Light with four codes!!! Fire-XJ XJ Cherokee Technical Forum 3 09-29-2009 06:59 AM
Check engine light, no codes... xjfan XJ Cherokee Technical Forum 4 07-27-2008 10:35 PM
check engine light / codes 1gopokes1 XJ Cherokee Technical Forum 1 07-12-2008 02:37 PM
Check engine light with no codes but 55? JJXJ XJ Cherokee Technical Forum 2 09-26-2005 03:33 PM
Check engine light, nobody can get codes thebubba1018 XJ Cherokee Technical Forum 26 10-29-2004 07:35 PM
