check engine light - JeepForum.com
post #1 of 2 Old 04-19-2008, 05:30 PM Thread Starter
jbvance
check engine light
hey guys was wondering if anybody knew what pins to jump to get the code for the check engine light on an 88 comanche
jbvance is offline
post #2 of 2 Old 04-19-2008, 05:54 PM
Pete M
1988 MJ Comanche
There are no codes. The E-light on the early MJs is on a mechanical timer set to go off after about 80k miles. It does not mean that there is anything wrong with the truck. The timer is a small clear box under the dash. Just unplug it and forget about it. Unless you live in a state that requires you to maintain it, then you need to get a new one at the dealership.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
check engine light on 2000 cherokee.. can i check it my self? Magic2979 XJ Cherokee Technical Forum 27 12-11-2013 09:46 AM
Check engine light came on. Is there a way to check the code? mhall101 XJ Cherokee Technical Forum 11 01-08-2012 08:01 PM
Maint Required light vs. Check Engine Light 92 Briarwood XJ Cherokee Technical Forum 20 09-16-2007 04:58 PM
check engine light/battery dummy light coming on iwishihad1 XJ Cherokee Technical Forum 4 08-23-2007 01:22 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 10:50 AM
