Center Console - JeepForum.com
post #1 of 6 Old 05-23-2008, 11:51 AM Thread Starter
rworks
Center Console
OK, just replaced the bench seat in my '87 MJ with buckets and now I want a center console.
Which year or body style XJ would I want to steal one from?
Yes, I know the MJ cab is kinda short and the center console prob is too long, but I got a hacksaw.
rworks is offline
post #2 of 6 Old 05-23-2008, 12:01 PM
jeepicon-com
I think they might all be very close to the same as far as fitment... I know my factory center console has a ash tray compartment on the back of it pointing at the wall.... which leads me to believe that it was originally designed to go in an XJ cause not many people fit in the back of the cab of my MJ
jeepicon-com is offline
post #3 of 6 Old 05-23-2008, 03:39 PM
Pete M
1988 MJ Comanche
XJs and MJs share the same center console. The XJ version will simply have vents running through it. 84-96 will work. Make sure you grab the small metal brackets that hold the console to the body.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 6 Old 05-23-2008, 05:30 PM
maddzz
1989 MJ Comanche
You should also grab the heater piece under the dash in front of the console. It is different from the one you have now.
maddzz is offline
post #5 of 6 Old 05-23-2008, 06:52 PM
XJohnnyC
XJohnnyC's Avatar
You can also use the 97+ console in an MJ. Then you'll have a couple of real cupholders.
XJohnnyC is offline
post #6 of 6 Old 05-23-2008, 08:37 PM Thread Starter
rworks
Awesome. I think the 97+ is the one to get. Off to the junkyard I go.
rworks is offline
center console colorfinger MJ Comanche Technical Forum 6 10-08-2007 05:49 AM
Center console wbacon XJ Cherokee Technical Forum 5 10-06-2007 03:00 PM
Center console went out nolosses4 XJ Cherokee Technical Forum 2 11-22-2006 06:14 PM
96 center console?? myth assassin XJ Cherokee Technical Forum 5 12-11-2004 11:21 AM
Want to take off center console.. BeachinXJ XJ Cherokee Technical Forum 5 01-01-2004 03:30 PM
