Caddy converter - JeepForum.com
post #1 of 10 Old 12-14-2012, 11:45 AM Thread Starter
Rican142
Caddy converter
What r the results of a blocked up catalytic converter
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 10 Old 12-15-2012, 06:32 PM
ftpiercecracker
1990 MJ Comanche
Overheating, and very noticeable loss of power, low exhuast pressure
ftpiercecracker is offline
post #3 of 10 Old 12-15-2012, 08:31 PM Thread Starter
Rican142
Would it cause sputtering and back firing?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #4 of 10 Old 12-16-2012, 02:23 PM
97_4popper
the times I've had one fail, it just either rattled or lost power and wouldn't rev.
No sputtering or backfiring.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #5 of 10 Old 12-16-2012, 05:43 PM Thread Starter
Rican142
Huh, aiight
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 10 Old 12-16-2012, 09:03 PM
97_4popper
If you are sputtering and backfiring, you may have a number of problems.
It sounds like timing. Perhaps timing chain slipped a tooth or is shot.
Are you over on Comancheclub yet?
My build thread:
post #7 of 10 Old 12-16-2012, 10:28 PM Thread Starter
Rican142
Could be, and yes but for some reason i cant log on
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #8 of 10 Old 12-17-2012, 06:22 AM
97_4popper
They have a funky activation that has to be done manually by an admin. I'll PM one of them and see if they can help.
My build thread:
post #9 of 10 Old 12-17-2012, 07:57 AM Thread Starter
Rican142
I just recreated one. Its lettin me log on and crud but i didnt get a comformation email
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #10 of 10 Old 12-25-2012, 08:39 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
CRUISER’S VACUUM TEST FOR EXHAUST RESTRICTION
Your vacuum gauge should come with an instruction booklet outlining the procedure. Hook the vacuum gauge up to a source on the intake manifold. Start the engine and note the vacuum reading. Usually 17 to 21 inches of vacuum. Throttle the engine up to 2,000 to 2,500 RPM for 20 seconds or so and the vacuum reading should stabilize to the same reading you got at idle. Let the throttle snap shut. The vacuum reading should shoot up about 5 inches of vacuum higher for a second and then come quickly down to the original reading. If the vacuum reading stays high and comes down slowly with jerky needle movements, you have an exhaust restriction.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
