Blown engine!! Need ideas ASAP! - JeepForum.com
post #1 of 4 Old 03-19-2012, 11:28 PM Thread Starter
Cburnett
1988 MJ Comanche
I threw a rod in my 254 stroker for no explianable reason. I receantly purchased a 88 mj , its my daily driver/toy. I have never swappeda engine. I leave for basic training in 45 days, been looking for a new engine and am over whelmed at all the options. Can some one point me in a cost effective way with a powerfull engine?
Thanks for reading and any ideas/comments. Open to all!
Cburnett is offline
post #2 of 4 Old 03-20-2012, 04:56 PM
ftpiercecracker
1990 MJ Comanche
if you have the coin to drop on it, a turbo will add a substantial amount of power, but expect fab work, and a LOT of tuning.
another stroker would be a good idea, poor man's 4.5l would be a good option (lookup Dino's stroker pg), but parts would be hard to come buy (not enough time). Hesco, Golen and Titan, are a few companies that make "bolt-in" strokers, but they can be pretty pricey.
chevy 350, a little more complex, transmission adapter will be needed, but engines are a dime a dozen and parts are as abundant as flies at a turd factory.
those are the two most common, but if you can dream it, its been done.
check out jeepstrokers.com if your interested in building/buying a stroker.
ftpiercecracker is offline
post #3 of 4 Old 03-20-2012, 11:38 PM Thread Starter
Cburnett
1988 MJ Comanche
Ok thanks for the advice! I think thats wat ima do is try the 350 or just build a stroker!
Cburnett is offline
post #4 of 4 Old 03-21-2012, 02:39 AM
trickydick
You could try a Ford 5.0, it's a 60 degree V-8 instead of the 90 degree 350. It might be and easier fit.
trickydick is offline
Blown Engine Diamond-x XJ/MJ Cherokee Non-Technical Forum 0 08-08-2008 06:58 PM
96 possible blown engine help? v1persrt10 XJ Cherokee Technical Forum 1 07-11-2008 10:12 PM
HELP ASAP! Blown Hose, No Heat, Frozen Anti-Freeze danw77 XJ Cherokee Technical Forum 8 02-11-2008 08:01 PM
Idling like k-rap... Some Ideas. Please Help, NEED TO PASS INSP ASAP! NightWolf0829 XJ Cherokee Technical Forum 3 09-13-2005 12:49 PM
Blown Engine? Hescrafty XJ Cherokee Technical Forum 6 12-08-2003 11:09 PM
