Blowing fuses... - JeepForum.com
post #1 of 9 Old 09-17-2007, 09:40 PM Thread Starter
blastsmith
2000 ZJ
Blowing fuses...
Ok guys pretend I don't know anything about the truck's electrical systems. I keep blowing my dash fuse no matter how big of a fuse I use. It was working fine this morning then tonight the fuse blows. What do I have to look for to fix this? I did nothing or haven't changed anything as far as electrical systems go. Thanks for the input.
What's the sense in having a Jeep if all it will ever see is paved roads?!
blastsmith is offline
post #2 of 9 Old 09-18-2007, 07:48 PM
Pete M
1988 MJ Comanche
I've had a loose wire ground itself out under the dash. My guess is there's a short somewhere but I can't be more specific without poking around in the vehicle myself.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 9 Old 09-18-2007, 08:53 PM Thread Starter
blastsmith
2000 ZJ
Are there any specific places to trace the wires under the dash or do I have to chase them down behind other crap? I know the guages are easy enough to pull out but don't want to pull anything else out if I don't have to.
BTW I appreciate you taking time to answer my questions. It seems you and LEAD mostly answer the questions around here in more threads than anyone. Thanks a bunch
post #4 of 9 Old 09-18-2007, 10:53 PM
Pete M
1988 MJ Comanche
If you have an after market radio, I would start there.
Also, what condition is your fuse box in?
Jeep on!
--Pete
My email:
Pete M is offline
post #5 of 9 Old 09-18-2007, 11:49 PM Thread Starter
blastsmith
2000 ZJ
Yes, I do have an aftermarket stereo, but I don't have the dimmer or light switch wires hooked to anything, they're taped off. I hooked it up back in feb.
My fuse box looks decent but I have NO clue whatsoever of how to pull it away from the firewall. I tried pulling the screws out of it with no luck getting it farther than a half inch away from the firewall. But that was months ago.
post #6 of 9 Old 10-03-2007, 11:16 AM
carnuck
1984 J-Series Truck
Check the lightbulb on the cigarette lighter. Mine shorted. Also the headlight switch may be bad (the variable resistor wire can flop around and short out) SHort in the interior light will do it too.
carnuck is offline
post #7 of 9 Old 10-04-2007, 02:08 PM Thread Starter
blastsmith
2000 ZJ
The interior lights work fine from the switch. I will check out the lighter bulb tho, but it's going to wait until I figure out why the tranny won't come any further than a half inch off the engine...
post #8 of 9 Old 10-04-2007, 02:48 PM
Pete M
1988 MJ Comanche
I had that happen with my newest truck and it turned out that I missed a couple small screws holding the engine to the trans inspection plate (or whatever it's called). D'oh!
--Pete
My email:
Pete M is offline
post #9 of 9 Old 10-05-2007, 01:31 PM Thread Starter
blastsmith
2000 ZJ
--Pete
I suspect the same of mine, or whatever caused the clutch to lock up is somehow caught up inside somewhere. I'm going to look into that tonight and find out what exactly it is.
Blowing fuses curtsjeep XJ Cherokee Technical Forum 3 07-26-2009 07:49 PM
fuses keep blowing..need help mmaverick88 XJ Cherokee Technical Forum 3 06-25-2009 10:00 PM
always blowing fuses in 99 xj please help weegie22 XJ Cherokee Technical Forum 3 06-02-2009 09:30 AM
Blowing Fuses Razor. XJ Cherokee Technical Forum 6 06-21-2006 10:55 AM
Blowing fuses.....why? PRYDE XJ Cherokee Technical Forum 3 07-14-2005 11:33 AM
