Quantcast best option for rear axle? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > best option for rear axle?
Old 06-12-2006, 03:33 PM   #1
rockcrawler16
Hi guy's (sorry for my bad english)
Well i'm from europe and in europe yearly we need to let the gouvernement inspect our vehicles. so we cant realy adapt anything about our suspension.
now i bought a '90 MJ where they adapted realy a lot. they putted the springs over the axle for sheap lifting but the way they did was deadly. even a ten year old can weld beter. its a 35 in the back
Now the MJ is sow rear in belgium that i can't find the good axle to put under it.
wat is my best option to put under it with the least welding?
an XJ 35 or an YJ 35. keeping the springs over the axle.
with an xj axles i just need to reweld the rigth atachement of the shockabsorber to the rear! wright?
anyone experience?
or a link for ordening a housing online in export?
rockcrawler16 is offline   Reply With Quote
Old 06-12-2006, 06:38 PM   #2
87manche
The shock mounts are on the u-bolt plates. So with a new axle all you need to do is weld perches onto it. I believe they are 42" apart.
An XJ or YJ axle will be the right width, see if you can't find a D44, it's much stronger than a D35.
I put an XJ under my MJ, I kept it SUA though. It just takes welding perches onto it.
87manche is offline   Reply With Quote
Old 06-12-2006, 07:36 PM   #3
LWB
Both the XJ and yj will require rewelding perches. (The XJ is SOA, but the perches aren't quite in the correct location)
Why not just reweld the perches on your existing D35?
'81 Scrambler on 34x9.50 Swampers and stuff...'69 CJ6 on 38x11.50 Boggers and stuff...'70 CJ6 on 36x12.50 Swampers and stuff...'02 Wrangler X on 38x11.50 Boggers with stuff....
LWB is offline   Reply With Quote
Old 06-25-2006, 10:15 PM   #4
ASE-MJ
Dont Know If You Have Alot Of Ford Explorers Or Rangers But If You Do You Could Do The Ford 8.8 Swap... It Can Be Done In A Afternoon With A Couple Of Spring Perches, Angle Gauge And A Welder... Its An Awesome Swap... Very Strong Avle Housing Tubes, And Axles.
1997 TJ 2.5L 5speed.....
ASE-MJ is offline   Reply With Quote
Glock Forum
