Battery Sparking - JeepForum.com
post #1 of 3 Old 03-14-2012, 12:20 PM Thread Starter
Craft95ZJ
1986 MJ Comanche
Battery Sparking
Jeep has been sitting in a barn for 3 months for the winter ran fine prior to storage. Changed the filter/oil ran some carb cleaner on the intake and carb to get the dust off of it. I Let it sit for 10 minutes, primed the carb shut the hood....no start. Popped the hood checked terminals all was good starter sounded good. tried it again every time I turned the key to the start position there was a big @ss spark off the negative terminal motor cranked but no start. I'm assuming its starter/solenoid related, checked fuses, but that's all the further I have gotten. just want opinions. BTW battery is new as well as +/- cables.
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #2 of 3 Old 03-14-2012, 01:20 PM
BigRedWilkey
Did you try jumping it? Sometimes the battery will spark even when it's bad.
BigRedWilkey is offline
post #3 of 3 Old 03-14-2012, 01:27 PM Thread Starter
Craft95ZJ
1986 MJ Comanche
I did not, the battery was at full charge It cranks just fine just no start (not my main priority right now), just seems like its drawing high amperage at first causing the terminal to spark.
HELP... First Jeep and it's not sparking... legendofgotham XJ Cherokee Technical Forum 1 03-11-2012 12:05 PM
battery 1993F250 XJ/MJ Cherokee Non-Technical Forum 2 12-15-2010 10:33 AM
Dual Battery w/ battery in the trunk laxsmith23 XJ Cherokee Technical Forum 2 12-08-2008 05:57 PM
Dual battery with one battery in the rear. Atticus1354 XJ Cherokee Technical Forum 2 11-25-2007 12:36 AM
Battery 4x4cherokee6 XJ Cherokee Technical Forum 7 10-24-2004 05:46 PM
