back fire - JeepForum.com
post #1 of 6 Old 01-17-2013, 05:44 AM Thread Starter
mj86
1986 MJ Comanche
back fire
I've changed distributer, plugs, wires, air filter, oil change, tune up. Still getting back fire, any ideas.
Thanks for any help
Mj86
mj86 is offline
post #2 of 6 Old 01-17-2013, 03:16 PM
mj40
1989 MJ Comanche
double check the firing order- no spec's on the truck???...so i cant give you this info- other than look at the intake for the firing order-4cyl 1342...6cyl-2.8l chev 123456 135 passangerside 246 driverside- make sure to start the wires on #1
check the timing??
mj40 is offline
post #3 of 6 Old 01-17-2013, 05:40 PM Thread Starter
mj86
1986 MJ Comanche
fire order
It has a 2.5L. There is no rime or reason, it does it when it is hot and cold. Sometimes real loud and sometimes soft and sometimes it doesn't do it at all. So confused.
MJ86
mj86 is offline
post #4 of 6 Old 01-17-2013, 05:43 PM Thread Starter
mj86
1986 MJ Comanche
MJ40, thanks for your help. I'm a true beginner when come to working on vehicles.
mj86 is offline
post #5 of 6 Old 01-17-2013, 06:14 PM
mj40
1989 MJ Comanche
need to know is it backfiring through the exhaust or the intake?
how does it idle/rpm? rough may have a bad intake or throttle body gasket
this link may help just to verify the base timing is ok...
http://www.4wdmechanix.com/Tuning-an...-TBI-Four.html
mj40 is offline
post #6 of 6 Old 01-22-2013, 04:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There are some vacuum lines just below the throttle body that crack and rot. Also, remove the ground strap from the firewall, scrape the paint off, shine up the connector, and reinstall securely.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
