Ba 10 trannt question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Ba 10 trannt question
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 07-17-2012, 08:17 AM   #1
Rican142
Why are the ba/10s such a bad transmission
Rican142 is offline   Reply With Quote
Unread 07-17-2012, 08:21 AM   #2
Jeff88
Here is a good link to read...
http://www.novak-adapt.com/knowledge/ba10_5.htm
The 10/5 transmission had a very poor record for durability and service, and consequently had the distinction of being the transmission with the shortest production run in Jeep history. It was gradually replaced by the AX15 during the 1988 model year.
Jeff88 is offline   Reply With Quote
Unread 07-17-2012, 11:35 AM   #3
Rican142
Wow, thanks for the answer, I will Def be looking into replacing mine when it goes
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Unread 07-17-2012, 05:18 PM   #4
DeejayZeejay
1994 ZJ
If you maintain it, should last a long time. I hope because I have the BA as well...
Jeeps 4 Life!
DeejayZeejay is offline   Reply With Quote
Unread 07-18-2012, 06:13 PM   #5
whowey
1988 MJ Comanche
The OO of my truck got 140k on his first BA-10.. I've got 125k on the second one. I haven't had any issues at all.
1988 MJ
1990 XJ A whole mess of stuff
1990 FSJ CS-130
1994 ZJ Happily gone
whowey is offline   Reply With Quote
Unread 07-19-2012, 12:48 PM   #6
Rican142
Well is it ok for slight offroading, nothin serious just alil fun with it
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Unread 07-19-2012, 06:31 PM   #7
Jeff88
I have beaten on my BA10 pretty hard. It has some weaknesses, and it is not the preferred transmission by most people.
Having said that, you are fine to do some wheeling with it, a lot of people do, just don't be shocked when if it starts acting up.
Not everyone has the cash or the means to immediately swap transmissions, my advice is just to take it somewhat easy, and some day if it breaks, consider replacing it with a stronger unit.
Unread 07-19-2012, 06:59 PM   #8
5-90
1988 XJ Cherokee
Because the synchroniser rings are aluminum, the gears are actually too hard (a common failure is stripping teeth off of a low-range gear or two,) and it was designed for the Peugeot 505. Ergo, it's horribly misapplied in a light truck.
Good news? It swaps readily for the later AX-15, which is a Toyota light truck gearbox. Go to www.naxja.org, and search for "Let this be THE Peugeot to AX-15 Swap Thread!" for all the information you should need on the swap.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote
Unread 07-20-2012, 12:35 PM   #9
Pete M
1988 MJ Comanche
if it's fine now, just keep it topped off with oil and cross your fingers. Don't ever pay to have one fixed though. just be prepared and do the research on swapping it out.
I had one self destruct in a 2wd MJ while cruising down the highway coming home from work. No warning, just BAM! blew a hole out the side and drained itself of oil. was still able to limp home, though most of that was while being stuck in 3rd.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email: petermontie@hotmail.com
ComancheClub.com/forums
Pete M is offline   Reply With Quote
Unread 07-20-2012, 08:04 PM   #10
DeejayZeejay
1994 ZJ
What did you swap in after that? AX-15? Probably going to do this soon...
Jeeps 4 Life!
Unread 07-20-2012, 08:55 PM   #11
Pete M
1988 MJ Comanche
yup. did a 4wd conversion at the same time.
Unread 07-21-2012, 10:38 AM   #12
Rican142
How hard is it to do a 4wd convo
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Unread 07-21-2012, 02:27 PM   #13
Pete M
1988 MJ Comanche
there are some tricky spots depending on what parts you use (so do all your research first), but it's no harder than swapping out a trans and axle.
Unread 07-21-2012, 03:45 PM   #14
DeejayZeejay
1994 ZJ
Im just looking to swap the trans... Got my zj for 4wd fun : ) I heard the bellhousings differ a little bit.
Jeeps 4 Life!
Unread 07-21-2012, 04:31 PM   #15
Pete M
1988 MJ Comanche
far as I know, the bellhousings differ in no way from 2wd to a 4wd version of the same engine/trans/year.
