axle swap - JeepForum.com
post #1 of 24 Old 03-20-2006, 07:30 PM Thread Starter
jeepcomanche88
jeepcomanche88's Avatar
axle swap
sry guys if this is a repost,
Ok now that i got my 33s i was wanting to swap the 35 to a 44. I want to know what all i would have to do for it to work right? is there any break swaping involved? is it really worth it?
jeepcomanche88 is offline
post #2 of 24 Old 03-21-2006, 12:34 PM
Burls
well if you get a danna 44 from an other mj it will bolt right in...but i believe you'll need to pick up a different length driveshaft. Bake wise the 44 uses 10 inch drums and the 35 uses 9 inch drums and i dont believe you can swap them.
Burls is offline
post #3 of 24 Old 03-21-2006, 12:58 PM
Pete M
1988 MJ Comanche
The Ford 8.8 from an Explorer is an even better choice if you can get leaf mounts welded on. Stonger, newer, more available, and 96+ have disk brakes. The wheel bolt pattern is the same as your Jeep and the gear ratio choices are 3.55/3.73/4.10. The axle is about an inch narrower than the Dana 35, but that's not much. If it bother you, the best fix I've heard of is to buy a 1.5" wheel spacer for ONE side, bolt that up to the passenger side to scoot the a little closer to the centerline, and then center the axle and weld on the perches. If I didn't already have an MJ D-44 lying around, I'd be going with an Explorer 8.8. Stay away from other 8.8s from ranger/cars/f-150s because they are either weaker or too wide/narrow.
car-part.com can help locate any axle you want.
This site will give you an idea of what's involved with the swap.
http://www.jedi.com/obiwan/jeep/ford88.html
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 24 Old 03-21-2006, 06:21 PM Thread Starter
jeepcomanche88
please excuse my stupidity but what is so bad about the dana 35?
post #5 of 24 Old 03-21-2006, 07:53 PM
a4xnut
1989 MJ Comanche
For stock purposes it is adequate, but it doesn't hold up so well to large tires and off-road punishment, especially with something like the 4.0 for power.
The non-C-clip 35's will hold up to 33's with the 2.5 or 2.8. I beat on one for years in my 2.8L XJ with 33's and 34's. I did end up swapping in a D44 when the 35 died, but it died from lack of oil when I managed to put a tiny hole in the cover and didn't notice it until it locked up going down the freeway at 70 mph... and something like that would have killed any axle.
Paul W.
Had God not driven Man from the Garden of Eden, the Sierra Club would have.
'94 XJ Country 4dr4.0L HO, AW4, NP242
'89 MJ Shortbed 4.0L, AX15, NP231, D44
'86 XJ Laredo 4dr 2.8L, A904, NP207, D44, full-floater HP D30, lockers, winch, etc.
'71 CJ-5 Project
a4xnut is offline
post #6 of 24 Old 03-21-2006, 08:28 PM
Pete M
1988 MJ Comanche
The Dana 35 is, *at best*, a light-duty axle. I killed the only one I'd ever driven on with a 2wd MJ and 30" tires. I own 3 MJs and as soon as I finish building the '90, they will be running an MJ Dana 44, MJ AMC-20, and a fullsize Ford 9". No more Dana 35s for my fleet. But there are literally millions of them out there and they can be found for dirt cheap. So feel free to drive them till they die, just bring spare shafts (and make friends with someone who owns a trailer).
Jeep on!
--Pete
My email:
Pete M is offline
post #7 of 24 Old 03-21-2006, 08:40 PM
a4xnut
1989 MJ Comanche
The 4.0 doesn't seem to have any trouble destroying a D35, but mine lasted >200,000 miles (and ~half of those were with big tires) before I killed it out of my out neglect/stupidity behind the 2.8 - and I've never been very kind to that poor XJ. I've laid it on its side, broken motor and tranny mounts, put the fan thru the radiator, broke driveshafts and transfer cases and even broke an alloy 297 front axle shaft in the D30... but the poor maligned D35 kept plugging on up to the day it starved for oil.
Go figure.
Maybe the fact that it's a non-Clip version
Or maybe it was built on a Wednesday.
Paul W.
'71 CJ-5 Project
a4xnut is offline
post #8 of 24 Old 03-21-2006, 09:04 PM
Pete M
1988 MJ Comanche
Even my Peugeot outlived my Dana 35.
But in its defense, it did last about 170k before it died.
Jeep on!
--Pete
My email:
Pete M is offline
post #9 of 24 Old 03-21-2006, 09:09 PM Thread Starter
jeepcomanche88
well dose anybody have a complete how to swap the 35 for the 44 and i only want the 44 i dont want the ford. thanks
post #10 of 24 Old 03-21-2006, 10:04 PM
JFD
I tried to fight it but I need to ask.....<hijack> The Mazda Navajo is pretty much a Ford Explorer, right? Does that have the 8.8 in it also? If so I might have a line on a free one (with pretty cool rims on it) </ hijack>
Sorry about the hijack but it was sort of on topic.
John
JFD is offline
post #11 of 24 Old 03-21-2006, 10:25 PM
Pete M
1988 MJ Comanche
My research says yes.
Jeep on!
--Pete
My email:
Pete M is offline
post #12 of 24 Old 03-22-2006, 07:17 AM
cj7xjmj
cj7xjmj's Avatar
Same animal. I dont think they made the after 95 though so finding one with disc brakes will be hard.
As far as what to do to swap in any rear axle that was not originally made for that vehicle is you need to do research... there are planty of write ups out there concerning this.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #13 of 24 Old 03-22-2006, 09:24 AM
a4xnut
1989 MJ Comanche
If you got the D44 from a MJ, it would just be a matter of removing the D35 and installing the D44. You should get a 44 with the brakes and drums and get the shock mount plates. The D44 has bigger tubes than the 35. (Alternately, you could slot the holes on the 35 plates, - at least you can on the XJ. You'll need new U-bolts, too. Finish the job off by bleeding the brakes.
Paul W.
'71 CJ-5 Project
a4xnut is offline
post #14 of 24 Old 10-23-2012, 06:38 PM
barberj
Is it possible to replace a D35 with a D34?
barberj is offline
post #15 of 24 Old 10-24-2012, 09:31 PM
martin809
What about the 8.25
martin809 is offline
Axle Swap Jeep_siihb XJ Cherokee Technical Forum 12 04-08-2009 10:00 AM
Axle swap help csramsey640 XJ Cherokee Technical Forum 1 11-02-2008 06:26 AM
axle swap cherokeeman90 XJ Cherokee Technical Forum 2 01-16-2008 08:07 PM
Axle swap ? Drrm80 XJ Cherokee Technical Forum 5 02-14-2006 12:35 PM
Axle Swap Jeepin_XJ_101 XJ Cherokee Technical Forum 9 06-01-2005 07:42 AM
