Axle swap - JeepForum.com
post #1 of 2 Old 05-06-2013, 05:07 PM Thread Starter
hairyjeep66
Axle swap
The question is will the hubs off an 88 mj Dana 30 w/disconnect work on the 95 xj w/o disconnect non abs axle. I know there a size different in the brake rotor but is the bolt holes distant and pattern the same??
hairyjeep66 is offline
post #2 of 2 Old 05-12-2013, 08:23 AM
mj40
1989 MJ Comanche
youll need to swap everything from the bj/knuckle outward...the bj's are the same so knuckle/hub/rotor/caliper from one to the other..and axle shafts if using a disconnect housing and going with a one piece shaft, youll need to change the seals(theres a write up somewhere, i've done it)
mj40 is offline
