-   MJ Comanche Technical Forum (http://www.jeepforum.com/forum/f53/)
-   -   Axle swap (http://www.jeepforum.com/forum/f53/axle-swap-1519602/)
hairyjeep66 05-06-2013 04:07 PM
Axle swap
The question is will the hubs off an 88 mj Dana 30 w/disconnect work on the 95 xj w/o disconnect non abs axle. I know there a size different in the brake rotor but is the bolt holes distant and pattern the same??
mj40 05-12-2013 07:23 AM
youll need to swap everything from the bj/knuckle outward...the bj's are the same so knuckle/hub/rotor/caliper from one to the other..and axle shafts if using a disconnect housing and going with a one piece shaft, youll need to change the seals(theres a write up somewhere, i've done it)
The time now is 09:28 AM.
