axle identification tag dana 30 - JeepForum.com
post #1 of 4 Old 07-12-2010, 06:01 PM Thread Starter
jebnmikki
2006 KJ Liberty
the tag on my front dana 30 is readable problem is the rear dana 35 has been swapped in from a junk yard as there is markings on it I know I am gonna have to jack it up and pull the cover and count the teeth to know what gear ratio it is. but the front tag has these numbers on it.
8953000394
10 41-10
does any one know how to decode this tag?
2006 Liberty CRD stock for now.
Colorado jeep club member # 186
jebnmikki is offline
post #2 of 4 Old 07-12-2010, 07:44 PM Thread Starter
jebnmikki
2006 KJ Liberty
ok looked up the numbers on the tag and they say its a dana 30 with 4.10 gears so I pulled the cover and the gears also say 41-10 looked the part number on the ring gear up and it says they are 4.10 gears. so the front is known now I need to pull the rear cover and see what gears it has.
Jeff
post #3 of 4 Old 07-17-2010, 07:22 PM
Paradise XJ
1988 MJ Comanche
The rear should be the same unless the PO screwed up
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #4 of 4 Old 07-19-2010, 11:17 PM Thread Starter
jebnmikki
2006 KJ Liberty
the rear has been swapped some time before I bought it.
axle identification for newbies bassackwards XJ Cherokee Technical Forum 2 07-29-2009 10:46 AM
axle identification packie88 XJ Cherokee Technical Forum 4 04-03-2007 08:52 PM
Axle Identification mfinkler XJ Cherokee Technical Forum 5 02-21-2007 05:52 PM
Rear axle identification miketyson XJ Cherokee Technical Forum 2 02-12-2007 06:27 PM
Axle Identification rfauber XJ Cherokee Technical Forum 0 01-10-2006 08:36 AM
