axel questions - JeepForum.com
post #1 of 12 Old 10-05-2012, 07:34 PM Thread Starter
Rican142
axel questions
How do I find out what kind of rear and front axel I have and what should I be hopeing for
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 12 Old 10-05-2012, 10:48 PM
mj40
1989 MJ Comanche
most common, dana 30 -front and dana 35 rear for the year, option/metric ton package had a dana 44 rear(the holy grail)...
http://coloradok5.com/axleguide.shtml
mj40 is offline
post #3 of 12 Old 10-06-2012, 10:12 PM
ftpiercecracker
1990 MJ Comanche
take a picture of the differential covers for both of them and post em. We will be able to tell you whats what within a few seconds of seeing them.
ftpiercecracker is offline
post #4 of 12 Old 10-07-2012, 07:03 PM Thread Starter
Rican142
Can do(as soon as it stops raining lol) but its only 2x4
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #5 of 12 Old 10-16-2012, 01:36 PM Thread Starter
Rican142
Well looks like its a Dana 35 rear
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 12 Old 10-16-2012, 01:36 PM Thread Starter
Rican142
Is that good
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #7 of 12 Old 10-16-2012, 02:30 PM
mj40
1989 MJ Comanche
they're not bad if they are taken care of, not abused..i had 31's and did mudding, rock climbing with mine, now i have 33's , most say thats the max size for a dana 35, i'm still searching for a d44 or a ford 8.8 with 4.10s to match my front diff gears..
best to open the diff cover and check the gears, take a pic and post it if your unsure, look close at the center gears/spider gears..they are the weak link and when they go they take the ring and pinion gears too..
mj40 is offline
post #8 of 12 Old 10-17-2012, 08:50 AM Thread Starter
Rican142
Oh ok, what does different gearings do? Like if its a bigger number how does that differ from a smaller number
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #9 of 12 Old 10-17-2012, 03:10 PM
mj40
1989 MJ Comanche
hmm, i'm sure theres lots of info on the gearing out there...
say a gearing of 4.10 to a 3.73 or 354
the 4.10 the driveshaft rates 4.1 revs to 1 on the axle allows more torque to the axle but hurts the top speed of the truck and fuel economy.good for towing
a 3.73 or 3.54 would be better for top speed and economy. but the 3.54 would be less of a towing or light load towing..
hope that helped..and this
http://www.offroaders.com/tech/gear-ratio-chart.htm
mj40 is offline
post #10 of 12 Old 10-19-2012, 06:59 AM Thread Starter
Rican142
Very much so, and how do I find out what my gearing is if its a d35
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #11 of 12 Old 10-19-2012, 03:03 PM
mj40
1989 MJ Comanche
4 cyl- most common 4.10's
4.0l- 3.54 or 3.08, mine had 3.54's for 89.
mj40 is offline
post #12 of 12 Old 10-20-2012, 06:40 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There's a tag on the diff with some numbers on it. Clean it up and post those numbers.
cruiser54 is offline
